03-16-2018, 08:46 PM   #16
Some More Test Images to Test Focus & Sharpness
I took a few more test images to test out my lens' focus/resolution. Just want to make sure that I don't have a faulty or unusually soft lens or anything, the possibility of which has been nagging me.
Update your browser to use Google Drive - Google Drive Help
They were all taken at f/8. With the image of the tree, I used center spot focus and focused on the middle branch. For the three identical landscapes, I used f/8 and focused on the foreground grass, middle of the frame, and distant buildings, respectively. These are unsharpened and unedited. I think it's safe to rule out that I have a bad lens, and just need to master my focusing and technique? I also did a basic indoor focus test with a printout of a focus chart, and I don't seem to have any front or back focusing issue.
03-16-2018, 10:27 PM   #17
pschlute's Avatar
QuoteOriginally posted by CPLTarun Quote
Raw files need to be processed. Importantly they need to be sharpened, usually in two stages, capture sharpening which is done early in the process by the raw converter, and lastly by output sharpening once the final image has been resized. Any unprocessed raw file will by it's very nature be soft.
03-17-2018, 01:04 PM   #18
Nothing wrong there. There was a tiny bit of cyan fringing which was very easily removed, but the image I looked at was all I could have wished for in sharpness. Get to know your camera and lens now and enjoy!
03-17-2018, 01:29 PM   #19
My DA 21 mm had focus trouble twice, and I know of others having the same problem. It can happen that the interior focussing becomes lose. In that case you lens will not proberly focus to infinity. Check sharpness for close and far objects. Check live view vs. AF. The problem can be fixed by yourself or by service at liow cost. Make tests to ensure that you have a mimsfocus problem and any other more general problem.
03-17-2018, 03:08 PM   #20
robjmitchell's Avatar
Don’t be afraid to use f11 on the 21, peak sharpness may be at F8 but F11 is still sharper than apertures larger than F5.6.
Its especially good for hyperfocal focusing, just adjust the F11 hyperfocal mark to the infinity distance and everything is in focus from 1m.
21mm, aperture, contrast, diffraction, disks, distance, exposure, focus, focus & aperture, google, harsh, hd da 21mm, horizon, images, k-mount, kp, lack, lens, pentax lens, photography, pictures, pixel, process, sharpness & af, size, slr lens, window
People If your pictures aren't good enough, you're not close enough,” Robert Capa Kerrowdown Post Your Photos! 35 07-08-2018 12:46 AM
For Sale - Sold: Pentax K5 IIs + Grip + FA43mm LTD + HD DA 21mm LTD + DA10-17mm Fisheye Duplo Sold Items 11 08-11-2017 10:09 AM
Is the Pentax DA* 300mm f4 lens sharp enough for wildlife? Theov39 Pentax SLR Lens Discussion 31 11-21-2016 11:25 PM
For Sale - Sold: DA 21mm Ltd Black, DA 70mm Ltd Black (ISO: 31mm Ltd Black) Evolution Sold Items 3 07-29-2011 08:03 PM
For Sale - Sold: DA 21mm LTD, FA 31mm LTD, and FA 77mm LTD (US) happygui Sold Items 6 10-17-2010 11:37 AM
All times are GMT -7. The time now is 08:19 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
