Originally posted by csandeep Thank you all! As a newcomer to this forum, really thankful for the thoughtful response. I'll research 24-70 before deciding. Also you are right I have only used a APS-C sensor cameras so really didn't expect 15mm to be super wide on FF.
I had both. Neither of these lenses makes sense on APS-C in my opinion. Both are wideangle designs for FF cameras that are overengineered for APS-C. 15-30 is a very nice lens, wide angle with zoom for FF, but it is quite big and you cannot easily fit a filter infront. Not a lens you want to take with you just in case you need more angle.
31mm has smaller filter thread, old style AF. It has special image signature, but not up to modern design standards. With APS-C I would go for the DA lenses designed for this format.
You may also consider the coming 11-18mm for APS-C for wide angle use. 100mm square filters should fit and you get a DA* lens with new specs.
24-70 is also not useful for APS-C, but great general lens on K1. 24-70 covers most focal length you really need for walking around and it dust and rain proof. For special images (on FF) I also take 77ltd with me.
