Originally posted by WPRESTO I noticed someone above liked the Rikenon 50mm f1.4. I went to a lot of trouble getting one when I was using a Ricoh XRM. It was mechanically really beautiful - ultra-silky smooth focusing ring - but I found the IQ consistently disappointing. Maybe I had a bad copy.
There's no comparison between the XR (which I assume you got with your XRM) and the P. Totally different lenses - looking into the glass, the elements are different sizes, the coatings look totally different also.
The XR was horrible wide open and only ok at f2. I didn't mind using it at f2 though because the colors were nice. I only compared it with my M 50 1.7 and the Rikenon XR 50 1.7 (the latter two being very similar in performance) and the Rikenon XR only caught up with the other two by f5.6.
This is the XR 50 1.4 wide open:
The redeeming quality of the XR was that it focused closer (I think around 1:5 or 0.2) while the P focuses identical to the Pentax 50s (0.17). It doesn't seem much of a difference but it is helpful for flower closeups. The XR also handles better - all metal construction while the P has some plastic. And the focus ring on the XR is one of the most delicious things I've ever had my hands on. I'm sure most of you know what I mean...
By the way, if anyone wants a Rikenon XR 50 1.4 that is stuck at wide open, they can have mine... I don't see myself using it as is. Once it's fixed, it's a lens with lovely rendering stopped down. Just don't use it wide open unless you want some unpredictable results
Originally posted by monochrome I rarely shoot a 50 wide open.
Which is probably why you sold me the Rikenon
Quote: * I shouldn’t have sold that Rikenon.
I'm thankful that you did
---------- Post added 04-04-18 at 03:15 PM ----------
As for the Pentax-M 50 1.7 vs 1.4 comparisons, here's a shot wide open from each:
50 1.4
50 1.7
Pixel peeping reveals that 1.7 to be much sharper in the in-focus area, even on a K10D.., I've taken a lot of shots with both wide open so I hope y'all don't need convincing
But the 50 1.4 still has this almost magical quality to it. And stopped down, both are tack sharp but I think I like the 1.4 colors a bit better. Not that the 1.7 isn't great in bokeh and color. They're both great lenses.
