04-20-2018, 08:15 PM   #1
Sigma 17-50mm question
After some deliberation, I've decided to get the Sigma 17-50mm f2.8 to use with my KP. I saw that there are two version of the lens for Pentax - one with stabilization and one without. I know that the in-lens stabilization won't work with the in body stabilization but I'm wondering how the stabilized lens will interact with Pixel Shift? Would using the stabilized lens lens let me use Pixel Shift handheld? Does that even make sense or am I misunderstanding how it all works?
04-20-2018, 08:23 PM   #2
QuoteOriginally posted by Vandon Quote
Since pixel shift requires a tripod, stabilization (whether in-lens or in-camera) should be disabled. Otherwise it could negatively impact the final product.
The KP is not equipped with this feature (Dynamic Pixel Shift came out on the K-1 II). Given the tolerances involved, it would be a longshot to expect any improvement to image quality using PS hand-held without DPS.
04-20-2018, 11:30 PM   #3
I have the Sigma 17-50mm f/2.8 EX DC HSM without stabilization, also mainly for use with my KP and as a matchup with my Pentax DA* 50-135mm f/2.8 lens. Sigma apparently omits the stabilization with this lens for Pentax because of Pentax bodies having SR. I got a great deal from B&H.
My impression is my copy is performing extremely well. Build quality is very good, images are sharp, AF is quiet, sure, and fast. I was not aware the same lens is available in Pentax mount having stabilization, but to me that would be redundant in a lens of this FL especially, and it would entail some on-lens switches and controls, making assembly more complex. The less un-needed complexity in construction might also make quality control easier and more precise. If I saw one offered for Pentax having stabilization, I would suspect the possibility of its being a previous model Sigma lens.
04-21-2018, 03:16 AM   #4
richandfleur's Avatar
Yep, sigma removed OS on most modern Pentax Mount lenses, other than the bigma style 500mm type ones.
Sadly sensor shift stabilisation doesn’t work in video mode on Pentax bodies, so there would still have been a place for it if Sigma had continued to include it.
As above though, you should only use one style of stabilisation at a time, and definitely have it off on a tripod, so not including OS is easier to work with for stills.
04-21-2018, 10:23 AM   #5
You probably can't use Pixel Shift handheld in that scenario; with PS it uses the sensor movement to adjust for the individual PS shots, and having the lens doing OIS would probably screw that up.
04-22-2018, 12:22 PM   #6
This newer, current Sigma version features their newer FLD glass technology, which is an advancement over their more traditional SLD glass, in correcting optical abnormalities for better all-around performance. I've read it has tested having virtually no field curvature, for instance, which means good focus at center point will indicate likewise good focus at the edges of the frame as well, at the same distance. Higher field curvature in a lens of this kind is rather common, so this is a real plus for this Sigma model.
04-23-2018, 10:21 PM   #7
Thank's everyone. I'm going to go for the newer non-stabilized lens.
04-24-2018, 02:17 AM   #8
Jonathan Mac's Avatar
I also have the non-stabilised version and have been extremely pleased with it so far - great build quality, excellent image quality and the near-silent focusing is lovely. I'd thoroughly recommend it. For short focal length like this I wouldn't be concerned about the lack of stabilisation.
17-50mm, k-mount, lens, pentax lens, pixel, shift, sigma, sigma 17-50mm, slr lens, stabilization
Sigma 17-50mm F2.8 vs Tamron 17-50mm and Pentax DA* 16-50mm Adam Pentax SLR Lens Discussion 89 12-28-2014 07:28 PM
Sigma 17-50mm F2.8 or Tamron 17-50mm F2.8 Stoney Pentax SLR Lens Discussion 7 01-24-2014 06:19 AM
Sigma 17-50mm F2.8 EX DC OS HSM v Tamron 17-50mm f/2.8 XR Di-II LD Aspherical [IF] lmd91343 Pentax SLR Lens Discussion 6 05-25-2011 07:04 PM
Quick question on Tamron 17-50mm vs Sigma 17-50mm Edgar_in_Indy Pentax DSLR Discussion 5 11-19-2010 01:08 PM
Pentax 17-70mm f/4 or Sigma 18-50mm f/2.8 or sigma 17-70mm f/2.8-4? shang Pentax SLR Lens Discussion 8 05-24-2010 05:30 AM
All times are GMT -7. The time now is 04:45 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
