05-02-2018, 05:18 AM   #1
HD Pentax-DA 55-300mm F4.5-6.3 ED PLM WR RE and K70 compatability
I purchased a HD Pentax-DA 55-300mm F4.5-6.3 ED PLM WR RE for my K70. K70 firmware 1.11
The lens seldom focused. Very infrequently it would focus but would then return to a rather dead state. My prime 15, 40 and 100 macro all work fine.
I did return it however wanted to add this versatility to my primes.
Bad copy? Other suggestions? Should I just be happy with a 100 mm max telephoto and let it go?
05-02-2018, 05:30 AM   #2
UncleVanya's Avatar
It should work. However it uses the sdm power contacts which none of your other lenses do. It is possible that your camera body has a problem related to this or something else that the PLM lens needs to function. I wish you had an 18-135 or other lens motor equipped lens to test to help narrow this down.
There are many zooms you can try other than the PLM version if that camera is failing to work with that lens type. However if it is in warranty I would get it checked. If it isn't in warranty then the next step would be to try another copy of the lens.
If all else fails there are non-PLM DA 55-300 lenses to try.
05-02-2018, 06:27 AM   #3
I think you've got an issue either with the lens, the camera or a combination of the two. I've got the same setup for travel or when I want a little less weight than my K-1, and it works fine for me. I've attached an example from a zoo trip two weeks ago.
PENTAX K-70  Photo
05-02-2018, 07:23 AM   #4
DW58's Avatar
I have the K-70 and the 55-300 PLM. The two play very well together for me. Focus is fast and accurate. Your situation doesn't sound normal. I'd try another copy of the lens. Here's a heavily cropped shot with this combo.
05-02-2018, 08:39 AM   #5
gump's Avatar
My lens arrived on Monday and would not focus. I went with the PF search and found an answer. Following the "fix" outlined by one user, I went to the back of the lens and around the glass is a small ring. I applied gentle pressure and it snapped into place. The lens works fine. Your problem does not sound identical but I offer this a possibility. Good luck.
05-02-2018, 03:32 PM - 1 Like   #6
Never had an issue with the K70 and this lens, of any description. This is a big crop from that combination. Would suggest either the power contacts are flaky/faulty/dirty or you need a new lens I think
PENTAX K-70  Photo
05-02-2018, 06:54 PM - 1 Like   #7
You all have convinced me to try another copy.
05-02-2018, 09:41 PM   #8
My copy really delivers. Check yours carefully and exchange if needed. But don't do w/o it.
05-03-2018, 04:27 AM   #9
QuoteOriginally posted by rptdc Quote
I like my copy with a K-70 taking pictures from my sailboat. Hopefully you will too.
They are designed to work together.
05-03-2018, 06:41 PM - 1 Like   #10
QuoteOriginally posted by jgnfld Quote
I will let you know when I get my sailboat. ☺️
05-03-2018, 09:17 PM - 1 Like   #11
SpecialK's Avatar
Don't do it! Any boat will drain your finances, unlike camera gear.
05-04-2018, 02:02 AM   #12
I have a new copy of HD Pentax-DA 55-300mm F4.5-6.3 ED PLM WR RE lens coming, hopefully arriving Saturday.
If this new copy of the 55-300 mm zoom works well with my k70, carrying it with my Pentax 100 Macro and small primes will be quite a physical burden. Or, maybe I just get that sailboat to transport my gear.
Unrelated question, which I can pose in a new thread if needed: Does the 55 - 300 PLM have any decent macro/close up capability?
05-04-2018, 03:05 AM   #13
Ya! Will you please explain to my wife how camera gear is not draining our finances.
05-04-2018, 05:40 AM   #14
UncleVanya's Avatar
HD Pentax-DA 55-300mm F4.5-6.3 ED PLM WR RE Reviews - DA Zoom Lenses - Pentax Lens Reviews & Lens Database
Per this the max magnification is 0.3x which is slightly better than my older version of that design (DA 55-300 not WR or PLM) which gets 0.28x; I've found the close focus pseudo macro of my lens to be pretty good.
05-04-2018, 06:39 AM   #15
K-70/55-300 PLM pics...
55-300mm, f4.5-6.3 ed plm, hd pentax-da 55-300mm, k-mount, k70, pentax lens, pentax-da, plm wr re, re, re and k70, return, slr lens
Trouble with KP and HD Pentax-DA 55-300mm F4.5-6.3 ED PLM WR RE talgarik Troubleshooting and Beginner Help 37 05-01-2018 01:15 PM
Trouble with K-S2 and HD Pentax-DA 55-300mm f4.5-6.3 ED PLM WR RE lens KimmersKorner Troubleshooting and Beginner Help 2 04-19-2018 04:40 PM
The new HD DA 55-300mm F4.5-6.3 ED PLM WR RE and focus breathing concerns anu l Pentax SLR Lens Discussion 3 12-09-2016 08:19 AM
HD Pentax-DA 55-300MM F4.5-6.3 ED PLM WR RE for 306 EUR beholder3 Pentax Price Watch 3 11-18-2016 05:08 AM
HD Pentax-DA 55-300mm F4.5-6.3 ED PLM WR RE Announced PF Staff Pentax News and Rumors 4 06-09-2016 03:45 AM
All times are GMT -7. The time now is 10:42 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
