I found a hard to pass deal on Kijiji, a used Vivitar 120-600mm (yes, 600!) F5.6-F8. It arrived today, it really is pristine, hardly looks as if it's been used.
The lens comes with a beautiful hard case ni excellent shape also. Even the clasp looks high-end:
The lens is a beast, at almost 5 pounds. It's longer than even the Pentax DFA 150-450mm. When mounted on the K-1 and extended to 600mm (with the built-in hood also extended) it's quite a sight (excuse the poor cell phone picture). At its shortest the lens is about 30cm long, I did not measure it fully elongated.
The lens has a solid tripod foot, with a wide metal ring which clicks at left and right 90°:
[IMG]
[/IMG]
Of course it's fully manual:
The zoom ring is a bit stiff, with all that glass to move around, but the focus ring (located far to the front) is so easy to operate that I can literally move it with one finger. When holding the lens barrel, it's thus possible to focus:
The front element is clean and takes 82mm filters. The cap is a plastic screw-on, quite unusual.
Here is the Vivitar next to a few other tele lenses. From left to right,
Pentax DFA 100mm macro WR
Signa APO 400mm F5.6 (that one will be sold, I don't need both)
Vivitar 120-600mm
Pentax DA 60-250mm
At their shortest focal lengths, focused at infinity, the differences are dramatic:
With each lens at its longest, with the hood in place when available, the differences are less important, mainly because the Sigma has internal focusing and the Pentax 60-250 has a very long hood...
I'll be testing the Vivitar optically when skies clear. I can already say that it shows some purple fringing, which is to be expected and is easy to correct. I can also say that using such a lens at 600mm is no easy trick. The electronic shutter on the K-1 and an IR remote are certainly useful. The K-1's tilting LCD is also very useful.
