07-20-2018, 03:30 PM - 5 Likes   #121
Des
Des's Avatar
Red Hill Show, Mornington Peninsula, Victoria. K-S2 + DA 55-300 PLM. Handheld, fairly close range, no flash.
07-20-2018, 04:18 PM - 2 Likes   #122
Des
Des's Avatar
QuoteOriginally posted by swanlefitte Quote
If you are posting pictures close to infinity please say what you are doing. I expect on tripod to be good but hand held? If handheld what shutter speed? Are you posting this is as good as it gets? or just that you can get this good. Tell us about your failures as well. Was this a one off or a cherry pick out of 2000? We know this lens can take great shots, what we need to know is where that stops or when skill takes over or where it just won't work.
For my part, I'm fairly selective about the photos that I post on Flickr and link to here. In other words, unless I post something specifically to show a limitation or frustration, the only inference to draw from my images is that these are in the better class of images that I can get with this lens.
As a general observation, I'd say that I haven't yet got any really good bird images (with good feather detail, etc, like I could get with my FA*300 f4.5) at 300mm with the PLM where the bird is more than say 10 metres away. The images I'm getting have about the same resolution as my DA-L 55-300 at 300mm. At close range (say up to 5 metres) the PLM does very well (as does the DA-L, although the PLM renders better). I can't yet say for sure that the limitation lies with the lens rather than with me - I suspect that it is both. I would need to use a tripod more to make that analysis, but I just find a tripod impractical for the sort of wildlife shooting I am doing.
To illustrate, here are some images of a Black-shouldered Kite. (Both 1/640th; the first is f7.1, the second f8; both low ISO. Both shot in RAW, processed in DxO PL and cropped.) I'd guess that the bird was 10-12m away. The light was very good - a bright cloudy day. A white bird against a cloudy sky has its challenges, but the kite stayed obligingly for some minutes. I took maybe 15 -20 shots, standing, leaning on the car or leaning on the window. I focused and re-focused. I got as steady a position as I could. My usual approach with the DA-L 55-300 is to stick with f8 whenever possible, even at the cost of higher-than-ideal ISO. I tried that. I tried different shutter speeds. But I just couldn't get anything better than this. They are not terrible, but not of a standard that I would normally show. I've calibrated the AF, I've tried faster shutter speeds, but this is about all I can get so far at this distance.
PENTAX K-S2  Photo
PENTAX K-S2  Photo
07-20-2018, 06:59 PM - 2 Likes   #123
Priest Lake in northern Idaho:
07-21-2018, 02:21 AM - 5 Likes   #124
Can do decent close up shots of sunbathing insects (cross-posted from the KP thread):
07-21-2018, 06:45 AM - 1 Like   #125
Doing Macro hand held from my walker. The challenge at 420 mm is keeping the active portion in the frame. I back focus so in affect lock the focal point in for a limited area so that it doesn't go in & out of focus blurring the target. The bee for example is good for at least a couple of good shots until it moves out of the focal range & I have to re-focus. Cropping is part of the technique in most of my shots with the PLM .
07-21-2018, 01:20 PM - 7 Likes   #126
Field in fog near Newport, WA, shot with KP:
07-23-2018, 06:54 PM - 4 Likes   #127
More tiny game hunting. Russian Sage makes a wonderful backdrop, and I like the bokeh I can get with this lens. Cropped, but not that much.
PENTAX K-50  Photo
07-23-2018, 07:07 PM - 1 Like   #128
SSGGeezer's Avatar
QuoteOriginally posted by Des Quote
I have had better luck in good lighting at f9 with my copy but keeping it at 260mm and shorter seems to be best for high IQ shots. Was the car running when you shot the images? If so, IBIS is not going to take those vibrations out since they are probably setting up a harmonic.
07-24-2018, 01:59 AM   #129
Des
Des's Avatar
QuoteOriginally posted by SSGGeezer Quote
Good thought, but no, I switched off the engine. I'll keep trying. I've been noticing the same thing about superior resolution when backing off the focal length a bit.
07-24-2018, 06:47 PM - 9 Likes   #130
Sunrift Gorge in Glacier NP, shot @260mm:
07-25-2018, 12:00 AM - 3 Likes   #131
Des
Des's Avatar
Waratah Bay, Victoria.
07-25-2018, 12:51 AM - 8 Likes   #132
Sandy Hancock's Avatar
More kangaroos I'm afraid. Once again they're just hanging around my favourite local trail, this time in the dim late afternoon light of mid winter.
Both taken at f/8.0 and ISO 1600 on the KP.
07-25-2018, 08:39 PM - 1 Like   #133
Winds Up Today !
Nice strong breeze on the Big Lake today. Thunder Bay / Lake Superior
55-300 PLM + 1.4 X TC WR / Hand Held / TVa - ISO 1600 max / see exif for details
07-26-2018, 06:44 AM - 2 Likes   #134
Baring Creek in Glacier NP:
07-26-2018, 03:21 PM - 1 Like   #135
When a kite surfer use an oversize kite, he/she turns into a paraglider
55-300mm PLM lens @ 55mm
attempt, birds, del, del norte pier, dusk, elephant, eye, f/6.3, f4.5-6.3 ed plm, flickr, hd pentax-da 55-300mm, k-mount, kp, lens, norm, norte, peanuts, pentax lens, pics, pier, plm wr re, pm, post, reflection, shot, slr lens, subject
HD Pentax-DA 55-300mm F4.5-6.3 ED PLM WR RE MacLoz Lens Sample Photo Archive 205 01-23-2023 08:58 AM
HD Pentax-DA 55-300mm F4.5-6.3 ED PLM WR RE and K70 compatability rptdc Pentax SLR Lens Discussion 15 05-05-2018 03:03 PM
Trouble with KP and HD Pentax-DA 55-300mm F4.5-6.3 ED PLM WR RE talgarik Troubleshooting and Beginner Help 37 05-01-2018 01:15 PM
HD Pentax-DA 55-300MM F4.5-6.3 ED PLM WR RE for 306 EUR beholder3 Pentax Price Watch 3 11-18-2016 05:08 AM
HD Pentax-DA 55-300mm F4.5-6.3 ED PLM WR RE - No reviews whyhaveone Pentax SLR Lens Discussion 9 11-03-2016 02:36 AM
All times are GMT -7. The time now is 07:29 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
