05-10-2018, 07:47 AM   #1
Aperture problems with Pentax SMC P 18-250mm f/3.5-6.3 DA Lens
Hi everyone, I was wondering if anyone can help me????
I have a pentax K20D and am having problems with the aperture not stepping down when I take a photo or I use the DOF preview. It stays open at the maximum. I have taken the lens off and I can manually move the lever which seems normal. When I use the DOF preview the lever in the camera moves as normal. I have put on an old manual 50mm lens and everything works fine. ie DOF preview, exposure, ect.
I have looked at the aperture levers in the lens and everything works fine.
Has anyone an idea what could the problem be??
Looking forward to your input.
Wazza
05-10-2018, 07:56 AM   #2
Not a Number's Avatar
Try cleaning the electrical contacts on the lens mount. Does the aperture setting show in the viewfinder or "F - -"? The latter would be an indication that the lens is not communicating with the body.
05-10-2018, 08:05 AM   #3
I have just re cleaned the contacts and in the display "Av"at F11 when you press the shutter half down the whole display flickers and the F11 changes to F-- as it is flickering.
05-10-2018, 09:33 AM   #4
The f-stop display should hold steady in Av mode. Try cleaning the contacts on the lens again as well as on the body. Check to make sure neither the mount on the body or lens is loose. It could also be a slight alignment problem so try gently twisting the lens back and forth while it is mounted and the meter active.
18-250mm f/3.5-6.3 da, aperture, dof, fine, k-mount, lens, lever, pentax, pentax lens, pentax smc, preview, problem, slr lens, smc p 18-250mm
For Sale - Expired: Xmas in July! - DA L 18-50 WR RE, SMC DA 21, Tamron 18-200, SMC DA 15, DA 18-250 EarlVonTapia Sold Items 9 12-13-2017 08:07 PM
For Sale - Sold: DA 18-250mm, DAL 55-300mm, DA 16-45mm, DA 35mm f2.4, DA 18-55mm, ZX-7, Filt mackloon Sold Items 17 05-21-2011 02:20 PM
Which Zoom Lens? "Tamron AF 18-250mm", "Pentax-DA 18-250mm" or "Sigma 18-250mm" hoomanshb Pentax SLR Lens Discussion 4 07-30-2010 09:50 AM
All times are GMT -7. The time now is 08:37 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
