Originally posted by SSGGeezer
Conclusions please? I won't give DPR any clicks if I can avoid it.
Thanks!
I was pointing out that I can get large sharp photos of aircraft in flight using the 150-450mm lens hand-held at 1/320 second on the K-1.
I linked to DPReview to show my photos taken a week ago in the way I identified, so that you could judge whether they meet
your standards, or the standards of anyone else reading this thread.
Something that may be of interest is that I typically nearly always use "AF-C Spot" as my autofocus setting. I find I typically don't need anything other than the central AF point. (I doubt if I've used any other AF point since 2016).
I nearly always use TAv, because shutter speed and aperture are typically vitally important, and nowadays ISO is relatively unimportant. ISO-noise is probably the easiest problem to solve in software. (Although some panning problems can be addressed by "Filter > Sharpen > Shake reduction" in Photoshop).
