Originally posted by stevebrot Are you saying that the front element is loose in the optical group (wiggles within its setting) or that the front of the lens (filter threads included) is wobbly. A certain amount of play (very, very slight) is normal for the FA 35/2 and ability to attain focus on a distant object is typically limited by the infinity (hard) stop on the focus mechanism set at the factory. In contrast, a front element loose from the rest of the lens is not normal, would result in generally inconsistent performance, and might require professional attention.
Concerns about infinity focus performance are fairly common on this site and the reasons range from a damaged or poorly aligned lens to unavoidable side effects from evaluating distant objects with a high resolution sensor. Things get messy fast* and answers are seldom easy. Your live view experience under manual focus is a good example. If you feel that your lens has something broken inside or has fallen out of spec due to wear, your best option may be to consult a competent service facility where infinity focus can be evaluated on an optical bench and adjustments made, if needed.
* For example, my FA 35/2 comes up against its factory stop at about 70 meters distance and my FA 77/1.8 has a hard limit of about 150 meters (both evaluated in magnified live view on my K-3)? Both provide acceptable results at those distances and f/5.6 (or even f/4) since DOF covers to infinity and beyond, but then the discussion get messier still.
Thanks for the answer. To clarify, the front section where the filters and lens hood attach has some play both wobble and in and out. When I first tested it on the K-1 infinity focus was excellent, but I have to admit I only tested from f5.6 to f16.
When I purchased the DFA 28-105 I wanted to see it compared at 35mm with the FA35. It was then that I found that it had trouble locking in at infinity, and that distant details were soft. Yesterday i went back and did the LV test. Actually I think the pressure from installing and removing the click on lens hood is to blame for the wobble.
Seeing that the 28-105 is so sharp I will probably save the FA35 for low light scenes which normally do not require infinity focus. I was hoping that there was a DIY method of tightening the front assembly, however.
---------- Post added 05-23-2018 at 07:18 AM ----------
Originally posted by Fenwoodian .
Sounds like your front element needs to be tightened. Easy if one has the right tools.
The element is tight within the front assembly that moves in and out when focusing. Even if that was so, I cannot find a way to tighten anything there. Unlike my older lenses, there is not notch in front where a spanner could be inserted to turn the ring. What tools would I need to tighten this one?
