Welcome to the Pentax Forums!
Originally posted by Adam The only way to confirm would be to measure the actual radiation, but I do believe the 55mm F2 is known to be radioactive.
Yes, this is true on both counts, though, as with the Super Takumar 55/1.8, there might be some Super Takumar 55/2.0 examples that don't have radioactive thorium doped glass. The yellow-brownish discoloration (found on the rearward elements) is a good indication, however.
Originally posted by Ned Bunnell Results of UV Treatment:
Ned Bunnell on Instagram: ?08.05.17 Update on using the Ikea JANSJÖ LED work lamp to see how it reduces the Thorium fogging on one of my Super Takumar 50mm f/1.4 (7??
I too favor the Ikea JANSJÖ lamp for dealing with the yellowing. It works like a charm. As for the radiation, it is unlikely that your lens would cause health problems if used as intended. The is particularly true if it is mounted to a camera and/or is not stored in close proximity to you or a family member. Use of a metal rear cap might also decrease emissions, though I have no data on that.
