Originally posted by WhimsicalV
I had the HD Pentax-DA 16-85mm F3.5-5.6 ED DC WR but for whatever reason it was blurry and I could not take a good picture with it, even with a tripod. They all came out worse than my kit lens at the time. I did not try fine focusing, so I am not sure whether that would have solved my problem. Alas, it is very possible that I had no idea how to use it properly. What is the difference when it is HD? Does what I am saying make any logical sense?. . .
I apologize in advance if these are silly questions, but why is it better? . . .
Would you mind telling me why it is important to have the aperture constant?
I hold the international copy rights to all stupid and/or silly questions but I allow others to use them without charge
it is possible that you had a badly made lens, it happens
as far as doing anything special with an HD lens, I use mine just like my other lenses.
I currently have:
HD Pentax DA 3.5-5.6 16 - 85 mm wr 72 f
HD Pentax-D FA* 70-200mm F2.8 ED DC AW 77 f
HD Pentax-D FA 4.5 - 5.6 150-450mm ED DC AW 86 f
HD Pentax -DA af rear converter 1.4 AW
____________________________________________
HD is just the coating placed onto the lens
" Lens Coating
The lens name prefix smc or HD indicates the type of coating. SMC stands for Super Multi Coating and was introduced back in the 1960'es. Naturally this coating has evolved and been improved over time. HD stands for High Definition and is a new coating introduced in 2012. The purpose of a lens coating is to reduce light loss as light rays travel through the lens elements and also to reduce stray light reflecting off the lens element surfaces. The net effect is less flare, less ghosting and better contrast.
Certain budget lenses from the film era lack SMC or HD coating and have no smc or HD prefix in their name. "
here are a couple of articles discussing the difference between lenses made with the SMC coating ( the older style ) and the new HD coating
Pentax Launches New HD Limited Lenses - Pentax Announcements | PentaxForums.com Farewell to flare? Pentax’s HD Limited lens lineup gets a real-world test
______
" Lens Name Suffixes
The following abbreviations are used in lens names:
AL: Aspheric Lens. Special lens elements that improves the optical quality. Particularly valuable in wide angle lenses.
AW: All Weather. The highest degree of sealing against dust and rain.
DC, PLM or SDM: The lens has a built-in motor for autofocus (K10D, K100D and newer cameras can take advantage of this).
ED: Extra-low Dispersion. Special glass material which helps reduce chromatic aberration. Particularly valuable in tele photo lenses.
IF: Internal focusing. Focusing is achieved by moving lens elements within the lens. The lens barrel doesn't move. IF lenses generally focus faster than ordinary lenses.
RE: Retractable lens. The lens collapses in length when not in use.
XS: Lenses with an exterior design by Mark Newson matching the Pentax K-01. Works like an ordinary DA lens.
WR: Weather Resistant. The lens is sealed against dust and light rain.
http://www.mosphotos.com/PentaxLensesExplained.html
________________
pn most zooms, the aperture changes as you change focal length
a constant aperture zoom lens allows you to use the same aperture, should you choose to do so, at any focal length
the F2.8 70 - 200mm zoom allows me to use F2.8 at 70mm all the way to 200mm.
What is a Constant Aperture Lens
__________________________________________________
I will let the folks with better knowledge reply to your other questions
