Originally posted by LensBeginner Sticky/adhesive paper, maybe inside lenscap so it's minimally exposed to the elements? on lens body.
I think it will come off in the field, I definitely don't want to litter lol.
Originally posted by microlight Off the top of my head - why not take a 'reference' photograph with each lens on each camera, enter the lens adjustment made into the EXIF comments for each photo, and then store all the references in a separate folder? No physical marks or notes on the lenses at all, and you'll know where the references are.
I'm not sure how that helps me in the field?
Originally posted by BigMackCam I maintain a simple spreadsheet that includes all of my AF lenses and bodies, and keep a printout of it in each of the bags I use. For MF lenses, I don't bother setting AF fine adjustment as I don't rely on focus confirmation... I go by what I see through the viewfinder, or use Live View and a viewfinder loupe for best accuracy.
I have a spreadsheet already, Yes I could print it out, laminate it I guess, not a bad idea, maybe have it printed on the underside of my lens pouches or something so when I pull a lens out to swap I can read from the lens pouch lid flap or something...
I'm coming around to your way of not bothering with AF Confirmation with MF lenses tho, the only thing that's rubbing me up the wrong way in regards to that is;
a) If I have a User Mode set for Apply One (ie Fine Adjustments for AF lenses), then if you swap to a MF lens in this mode it will toggle not to Off but to Apply All (and the value will be whatever it was last set to from a power down, not what the lens might actually want)
b) Then I create a User Mode for MF lenses I hear you say? Could do, and ensure that Fine Adjustments are set to Off for this mode and rely solely on what I see. However, what I find annoying is I cannot remove the AF Points, AF Frame etc from that User Mode and save it. The Transparent Overlay settings is global and cannot be saved to a user mode, and of course sometimes I need the AF Points (AF scenarios etc), but then I find them plain annoying (all that red blinking screen) when using MF lenses, it's easier to concentrate with a blank viewfinder. But this involves menu diving unfortunately...
Originally posted by Sandy Hancock Sticker on lens cap with lens name (in case you get them mixed up) and the correction value.
But really, how many of your AF lenses will be used on both formats? And if the body remembers the correction values, why do you need to?
Sticker on the lens caps either facing out or on the inside I fear will just come off and this is for the MF lenses Fine Adjustments, not the AF variants (currently I have a Samyang 85/1.4, Takumar 135/2.5 and a Pentax A SMC 24/2.8 that are all MF but have varying degrees of different Fine adjustment values if using AF Confirmation with them).
I'm curious if perhaps using something like a pen but can rub off without damaging would work, almost like a gentle nail varnish or something, but can be removed easily with acetone etc...
