05-30-2018, 03:30 PM   #1
TerryL's Avatar
ND Filter users
Hello Folks,
I just bought an Irix 15mm and 100mm filter holder. The filter holder is made very thin, with a large aperture circle. The designer said that it won't vignett or leak light. The holder requires for there to be no foam seals on the filters. Is there a brand of good filters without the gasket? I was told that some brands come with a gasket, but the user needs to install it. That way, I could just leave it off. If I need to, how do I remove them? Your help is appreciated. I'm anxious to get some.
Terry
05-30-2018, 05:10 PM   #2
jatrax's Avatar
Does the Irix take a threaded holder? What threads?
05-30-2018, 05:20 PM   #3
In its description on Amazon it says:
"95mm front filter thread AND a rear gelatin filter slot for even more options. Filters can be cut by the photographer at 30x30mm. Lens hood mounts around the outside of the lens barrel, encircling the filter. Filters can be accessed through the lens hood, thanks to the small window. Ideal for working with circular polarizers, variable ND filters, etc."
05-30-2018, 06:13 PM   #4
jatrax's Avatar
OP: are you using solid NDs or ND grads? If filter threads are available that is the preferred method for solid NDs. If you are using ND grads then look at this holder: X100 Holder ? Breakthrough Photography
ND grads are not as bothered by light leaks but for solids the simplest way is to just use screw on filters. IMHO.
05-31-2018, 08:35 AM   #5
TerryL's Avatar
Yes. 95mm filter threads.
Terry
---------- Post added 05-31-18 at 08:41 AM ----------
Thank you. I'm pretty sure that filter holder will cause vignetting. Thank you.
05-31-2018, 10:33 AM   #6
TerryL's Avatar
What I really need to know, is there a brand of ND filters that don't have the gasket installed. Or, if not, how do I remove it? Knowing that would really be helpful. Thank you very much.
Terry
05-31-2018, 10:37 AM   #7
jatrax's Avatar
QuoteOriginally posted by TerryL Quote
Terry, I use both threaded and 100x150mm filters. Nothing I have uses a gasket so I am really not sure what you are looking at. Can you post a link to the ones with the gasket?
filter, filters, gasket, grads, holder, k-mount, pentax lens, slr lens, threads
Kenko Pro1d Lotus ND? Hoya filter kit II? Used filter choice. dr_Fell Pentax Camera and Field Accessories 8 09-06-2017 04:11 PM
For Sale - Sold: Sigma 17-50mm f/2.8 EX DC lens with UV filter, CPL and ND filter (price loveisageless Sold Items 3 05-21-2017 01:36 PM
"Recommended" variable ND vs "recommended" ND set madison_wi_gal Pentax Camera and Field Accessories 11 03-22-2017 12:19 AM
For Sale - Sold: Galen Rowell Filter set** ND-2G-HS and ND-2G-SS** P size 84mm x 120mm davidgreen3003 Sold Items 2 12-30-2013 02:05 PM
Variable ND Filter - Fader ND mark II yusuf Pentax SLR Lens Discussion 2 11-16-2010 11:39 AM
All times are GMT -7. The time now is 01:33 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
