09-20-2008, 06:27 PM   #31
For the OP:
I ran across something today on the Web. I was researching the fix for the Zenitar 16/2 infinity focus issue and found a posting where the user corrected the diaphragm pin issue:
DIY: "fixing" a Zenitar M 16 to use with a 5/7D/alpha - Dyxum forums - Page 1
The fix is detailed in the second post. In summary, the fix is to remove the aperture actuator assembly. With the actuator gone, the lens defaults to the stopped down state. Some time ago I also ran across a solution where a standoff sleeve was slipped over the actuator pin (from the inside) so that it is always depressed. That is probably the preferable route since it is easily reversible.
16mm, aperture, exposure, f2.8, f4, k-mount, pentax lens, shutter, slr lens, zenitar, zenitar 16mm f2.8
Zenitar 16mm question Jools Pentax SLR Lens Discussion 4 01-13-2010 09:59 PM
For Sale - Sold: Zenitar 16mm f/2.8 FE palmor Sold Items 5 09-12-2009 07:35 PM
Zenitar 16mm fisheye deudeu Pentax SLR Lens Discussion 19 04-05-2008 10:06 AM
Zenitar 16mm Flaco Pentax SLR Lens Discussion 11 02-22-2007 11:45 AM
All times are GMT -7. The time now is 10:35 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
