09-10-2008, 04:27 PM   #1
Pentax 16-50 mm da* problem
Plz help! After installation this lenses into my K20D i can't normally access menus. After pressing MENU button, menu shows in backscreen and dissapears in less than 1 sec - so i can access any settings... The same with Fn button.
So, I can create shots in MF mode only. After AF.C or AF.S changing i can create the shot.
09-10-2008, 06:01 PM   #2
Try cleaning the contacts on both the lens and the body. Even if they look clean.
If that doesn't work see if you can try another lens at a local shop.
Since that lens doesn't have the best track record it may be flawed, although I haven't heard of that one happening
09-11-2008, 05:28 AM   #3
During last 9 days i used Helios lenses without AF, and it works with no troubles...
09-11-2008, 06:29 AM   #4
the helios has does not transmit any information to the body and might have dirtied up the contacts when mounted
09-11-2008, 07:52 AM   #5
QuoteOriginally posted by k100d Quote
So i must clear contacts with alcohol?
09-11-2008, 08:06 AM   #6
Moderator Emeritus
Electronic contact cleaner with a clean microfibre cloth is best and don't use too much.
access, button, k-mount, menu, pentax lens, slr lens
K-5 battery problem? camera problem? user problem? imtheguy Pentax K-5 39 11-03-2010 06:02 PM
problem with pentax pz-1 / z1 molotvo Pentax Film SLR Discussion 6 12-20-2009 11:01 PM
Old Pentax problem groucho49 Pentax Compact Cameras 4 01-19-2009 02:48 PM
Card read problem K20d. Have you had this problem? rsi1986 Pentax DSLR Discussion 8 12-27-2008 05:25 AM
Problem, pentax 1.4x-s roy Pentax SLR Lens Discussion 11 03-03-2007 07:20 PM
All times are GMT -7. The time now is 04:31 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
