09-11-2008, 06:54 AM   #1
meszidik's Avatar
Change vivitar FD mount lens to K mount?
I bought 2 Vivitar lenses (400mm f5.6 and the series 1 70-210mm f3.5 macro(kiron) ) on impulse and they turned out to be Canon FD mount.
After googling, I realize there is no adapter for FD to K mount.
My theory is that the lens must be mostly the same and they just put different mounts on them for each camera system.
What I am wondering about is there a way to remove the FD mount portion and install a K mount on the lens instead?
Thanks,
-Mark
09-11-2008, 07:25 AM   #2
I have a series 1 70-210 f3.5 in pentax-k mount, and on that lens the rear element is almost as far back as the bayonet itself. Due to the shorter flange focus distance for FD I would suspect that either the back end of the lens (the bayonet-part) is longer for FD or, that a different lens element is used to give correct focus. If you have a photo of it (the rear end) I could compare it to the one I have. I guess it might require quite a bit of work to actually convert it to p-k.
I've also had a Vivitar 400mm/5.6 and there seems to be a lot of versions of that particular lens. A lot of them were made by Tokina (serial number 77xx?). Mine had an interhangeable tx-mount similar to the Tamron adaptall. I think in fact a lot of the 400/5.6 lenses were tx-mount. You can check out Rick Oleson's page for a photo of what it looks like: SLR Lens Mount Identification Guide
If your lens is a tx, you'll be able to find a suitable pentax-k adaptor for it. If it's a fixed fd-mount I don't think it will be worth the effort to convert it. I've had several generations of these lenses, up to my current Tokina AT-X AF, and to be honest, the older variants were not among the sharpest out there. The green(!) Vivitar I had was not nearly as sharp as the later models, and the manual focus Tokina had a really bad (3-4 pixels)purple fringing/CA.
09-11-2008, 08:47 AM   #3
Blue's Avatar
you would be better of selling the FD mount lenses or better yet returning them if they were listed wrong.
09-11-2008, 09:21 AM   #4
meszidik's Avatar
Yeah, reselling is probably the best bet, but these lenses don't carry much value when FD mount.
I can't really return because I got them via Craigs List and the guy told me he didn't know what mount it was. It was a gamble purchase, and I knew there was a chance I'd have useless (to me) lenses. I kinda like the challenge of converting them, but I have no experience and don't know if its even possible.
09-12-2008, 09:59 AM   #5
meszidik's Avatar
I removed the mount on the 400mm - its not a TX adaptor. I kept going thinking there might be a way to rig-up a K mount. I took it apart from the mount to the tripod collar. No luck. Now its become a real pain to put back together. Why are things always easier to take apart?
fd, k-mount, lens, pentax lens, slr lens, vivitar
For Sale - Sold: Vivitar 28mm f2 (Kiron) Lens In K mount - Like New warpedwoof Sold Items 4 05-07-2009 06:01 PM
Vivitar 70-210mm f4.5-5.6 Pentax KA mount lens mi2nc Pentax SLR Lens Discussion 0 11-29-2008 10:11 AM
For Sale - Sold: Vivitar 28mm f/1.9 lens (K-mount) Rykoh Sold Items 5 09-28-2008 07:38 PM
For Sale - Sold: FS 50mm f1.7 Vivitar lens K Mount Bob Tuttle Sold Items 0 12-18-2007 10:12 AM
change a mount on a vivitar varnco Pentax SLR Lens Discussion 4 05-22-2007 07:46 PM
All times are GMT -7. The time now is 01:41 PM. | See also: NikonForums.com, part of our network of photo forums!
