09-11-2008, 10:05 AM   #1
Aperture pin problem
Hi,
I recently got a good old VIVITAR 35-105mm/3.2-4 zoom (P/K-A) and I'm experimenting troubles with it.
As the mounting rail was too long to be used with a Pentax camera, I wanted to cut it a bit, as for Ricoh lenses. In order not to put metallic dust on the rear lens, I decided to remove the back of the zoom.
And the ... the third pin and spring jumped outr of the lens, and the little plate under the pin broke into three pieces.
Now, I only have the sping and the pin, and I can't get the "A" position work. I managed to use aluminum paper ang blue so that I could fix the pin again (and it cas move), but my K200D never get the aperture.
There's no resistor in that lens, only a sping, a pin, and a little metalltic square with "claws" (the one who was broken).
As anyone any idea in order to fix this ?
Where could I find schematics for this lens ?
Regards.
09-11-2008, 01:34 PM   #2
Lowell Goudge's Avatar
the pin and spring need to connect to the base of the lens mount when in the A position.
you would need to look but there should be a contact that gets connected only when the apature ring is turned to the A position.
As all manufacturer's accomplish this differently it is hard to guess without photos of the internals of the mount what you need to do.
aperture, aperture pin, k-mount, lens, pentax lens, pin, slr lens
M42 auto-aperture pin dilemma RioRico Pentax SLR Lens Discussion 21 11-10-2010 02:00 PM
Aperture pin on Helioses (Heliii?) MrCynical Pentax SLR Lens Discussion 11 03-01-2010 06:51 PM
M42 Voigtlander 90 Aperture Pin Problem Sirfishalot Pentax SLR Lens Discussion 4 01-15-2010 02:33 PM
Pentax AF-540 FGZ Locking Pin problem survey Sprags Pentax Camera and Field Accessories 30 01-16-2009 12:25 AM
All times are GMT -7. The time now is 03:34 AM. | See also: NikonForums.com, part of our network of photo forums!
