Show Printable Version 9 Likes Search this Thread
06-15-2018, 12:33 AM - 6 Likes   #1
Another good macro lens.
Hello,
For about 7-8 years I am working with my oldie Pentax 100 mm F 2.8 macro lens (it was used as I bought it) and Pentax K-3 camera. Together with macro flash I achieved quite satisfying results. As the years pass, I have noticed that quality of pictures have changed, very often image is not in focus and so on. So I decided to buy a new macro lens for Pentax. I would like to ask for advice.
I have read that Pentax 100 mm is good as Tamron 90 mm lens, but maybe there are other lenses that are a bit better than Pentax 100 mm f 2.8? I prefer macro zoom lens. I would be very grateful for your answers!
PENTAX K-3  Photo
PENTAX K-5  Photo
PENTAX K-3  Photo
06-15-2018, 05:04 AM   #2
LensBeginner's Avatar
Last one is top-notch... the different colors work together very well.
I would probably also try a tighter, but it's already very very good like this.
06-15-2018, 06:08 AM   #3
bertwert's Avatar
I agree with LensBeginner, they're all pretty good, and that last one is just great! Very good use
06-15-2018, 06:11 AM - 1 Like   #4
Sandy Hancock's Avatar
There's nothing wrong with any of those images.
I don't think you need a new lens at all.
06-15-2018, 06:28 AM   #5
normhead's Avatar
Did you see this.....
Macro-bokeh-test - PentaxForums.com
or this
Pentax FA* 200mm f/4.0 Macro IF ED Lens 200 f4.0 f4 SMC | eBay
How far the camera will be from the subject is the big reason for more focl length. But they all look pretty good to me.
06-15-2018, 08:44 AM   #6
Thagomizer's Avatar
QuoteOriginally posted by Precious Quote
Those shots look great! You've clearly got an eye for composition, which is more important than any equipment.
I'm thinking that your lens has probably not changed (unless it has quietly filled up with haze or fungus). My old screw mount Takumar macro lenses still perform superbly. I believe a number of Forum members regularly use macro lenses that predate your F 100. I'm wondering if somehow there have been changes happening behind your camera that a new lens might not address.
How do you focus? Viewfinder? Live view with focus peaking? Perhaps your eyesight has changed? I still have trouble nailing focus, but it's seldom my gear that's at fault.
Are your hands steady? I know mine shake, but I'm still determined to shoot hand held. If that means I have to take more shots to get keepers, so be it.
Are you shooting different subjects now than you were before? I've been doing a lot of shooting at higher magnifications. Going back to "just" 1:1 seems very distant and far away. My 1:1 lenses haven't changed, but what I'm shooting and how I want things to look has. I've had a longer focal length 1:1 macro on my "want" list for some time; currently 70mm is my longest lens in this regard. But with the more than 1:1 stuff I've been doing, the longer focal length wouldn't really help, unless used as the primary lens of a lens stack. If your capabilities or needs have changed, you should find that out before buying another lens, because a new lens might not solve the problems you are encountering.
06-15-2018, 11:06 AM   #7
bdery's Avatar
How in heaven did you manage to capture this last picture? Was the critter frozen before taking the shot? It's amazing.
06-18-2018, 05:27 AM   #8
Thank you very much for your comments and suggestions!
I guess I just want to make fresh winds in my macro photography to get better results and I thought that maybe a good new lens could make a difference..
06-18-2018, 05:29 AM   #9
99/100... it doesn't.
But it's certainly more enjoyable to play with a new toy train, so to speak...
06-18-2018, 06:49 AM   #10
normhead's Avatar
With macro, going to manual focus when the placement of the focal plane is critical can make more difference than a new lens.
06-18-2018, 01:07 PM - 1 Like   #11
...or you could buy a rail
06-18-2018, 01:23 PM   #12
SSGGeezer's Avatar
Why would you need a new lens? These shots are very good! If you need to convince yourself that water resistance is important, then the D-FA 100 WR is the lens for you, but you are doing great work with what you have here. I would be proud to claim any of these images.
06-18-2018, 01:42 PM   #13
swanlefitte's Avatar
If you mean replace your macro to do macro i can't see why since the iq is great already and the difference in focal length is cms closer or farther away. If its to use also for non macro i can understand.
If this is the case you should clarify and i am sure you will get more guided answers.
06-18-2018, 01:45 PM - 1 Like   #14
normhead's Avatar
QuoteOriginally posted by SSGGeezer Quote
To go on from here, you might want to experiment with focus stacking.
06-18-2018, 01:54 PM   #15
...hence the rail I was suggesting!
k-mount, lens, macro, mm, pentax, pentax lens, slr lens
Macro Another Rose, Another Visitor Kerrowdown Post Your Photos! 12 11-02-2019 01:18 AM
Another Time, Another Wall louparker Monthly Photo Contests 37 06-12-2018 10:01 AM
I need recommendations on a good quality Pentax lens. Not another 50mm. Thanks. Tonytee Pentax SLR Lens Discussion 17 12-20-2014 12:07 AM
Good morning, good afternoon, and good night TomTom Welcomes and Introductions 6 04-13-2014 05:13 AM
Reverse stacking for macro onto a 100mm macro lens - 28mm good? GibbyTheMole Pentax SLR Lens Discussion 10 04-27-2012 02:56 AM
All times are GMT -7. The time now is 05:48 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
