Originally posted by gatorguy Resurrecting this old thread.
I received my Zeiss Jena 35 2.8 (zebra) today. Love the close focus ability! But my M42 to K adapter doesn't have the proper flange to cause the aperture pin to depress. It only shoots wide open at the moment. What's my best option, just a different adapter, and if so is the authentic Pentax Adapter K a good choice?
Does the lens have an A/M switch? If so, preset the aperture you want, focus as required, then operate (and hold, if necessary) the A/M switch in the M position to meter and make your exposure.
If there's no A/M switch, the Pentax Adapter K is not the best choice if you don't want to modify the lens, 'cos it has no facility to operate the aperture pin.
As far as I'm aware most/all Pentax 42-screw lenses had an A/M switch, so there was no need to consider the need to actuate the aperture pin when the adaptor was designed.
So, you're either needing to find one of the uncommon aftermarket adapters with the internal flange that'll operate the pin for you, only use the lens wide open, or succumb to necessity and modify/adjust the mechanism to keep the pin depressed all the time.
Enjoy
