Originally posted by FotoPete For me, I just don't understand how lenses can cost so darned much...like more that the camera. Yes I saw the Canon Virtual Lens Factory video and there's alot of precision processing and manaul labour and perfection/inspection...but isn't a camera many more times complex? Nowadays lenses are far cheaper then they were back when it was all metal, full frame, had the aperture rings, smooth focus..etc.
My philosphy is that the lenses should never cost more than the camera itself. Of course its not reflective of the market today with thousand dollar lenses and an alphabet soup of specialities like "AL, DA, ED, Ltd, SDM, SR, *,... ".
The reason lenses are so expensive is
The design, plug the numbers into a Super computer, wait a couple hours and out the other end you have a lens design.
Optical glass is very expensive to make, it is incredibly expensive to cast, it is super incredibly expensive to machine. One minor mistake at any stage and the piece of glass is useless.
The you have to arrange the lenses, to a tolerance that is incredible, a 1/10th of a mm or less out and the lens wont perform as designed.
The another thing is coating the elements, not a cheap exercise, and not an easy process.
The aperture is a highly precise piece of equipment, not to mention all the electronics in them these days.
Lenses are highly complex highly precise pieces of equipment, the only reason they are more expensive is due to the high levels of automation in the construction process theses days.
Many people say that they cannot see the point in spending lots of money on lenses when a cheaper on will do, But when you see the qualities that i high end lens has you wont go back.
