06-20-2018, 06:59 PM   #31
The central 1/9th was very sharp, but the other eight sectors were soft and getting progressively worse to the edges, especially at the bottom and worst on the left. Worse than any field curvature I've seen, so I'm sure it was slightly de-centred.
Sounds like the A 20 I had, before it went to Eric Henderson.
06-20-2018, 10:19 PM   #32
clackers's Avatar
Clackers, show me where I ignored someone for promoting primes, You made the charge..
You weren't being serious in Post 10, Norm, and neither was I in Post 12 ... hence the smilies, right?
On a real point, you do a lot around here - 28,500 posts, nearly 9,000 likes, but you're of course no shrinking violet in pointing out errors made by others.
All well and good, but as I showed with the Pentax FA20-35 example, that has to apply to you too, you're not magically exempt.
06-20-2018, 10:25 PM   #33
clackers's Avatar
QuoteOriginally posted by bxf Quote
How do you actually do this? Do you stack one on top of the other, and if so, in any particular order? Or is there a hidden mount that enables you to mount two lenses at the same time?
No wonder my pictures are so bad, Bxf ... instead of just sitting on top of the camera, I should mount one of them in the K-1 first!
06-21-2018, 05:07 AM   #34
bdery's Avatar
QuoteOriginally posted by lytrytyr Quote
How does the FA 31 fare at 20mm?
My point exactly.
The 31 and 20-40 are wildly different, and comparing them is the same as listing their particular strengths and weaknesses. We already know what those are.
If you're an "f/8 and be there" photographer,
f/8 performance is what you live by,
especially if you need the depth of field.
I understand what you mean, and agree. What I want to stress is that purchasing the expensive FA 31 to use it at F8 makes little sense. It becomes a VERY expensive marginal improvement over consumer zooms. wider apertures is what makes this lens different (or better, unique, special, substitute whichever adjective you want).
da, dc, f/8, fare, hd, k-mount, length, lenses, limiteds, mm, pentax, pentax lens, pentax-da, re, slr lens, weight
Is Pentax secretly developing a D FA* 24-70mm f/2.8 ED DC IF PLM AW Lens? dcpropilot Pentax SLR Lens Discussion 9 06-18-2017 07:45 PM
Hi there. Screw drive vs PLM pulse. MichaelS Welcomes and Introductions 10 06-18-2017 04:10 PM
55-300 PLM or non-PLM version to K-1? Vignetting etc? HankVonHeaven Pentax SLR Lens Discussion 7 01-29-2017 09:54 AM
Other PLM lenses or updates with plm motor? Pentigor Pentax SLR Lens Discussion 7 07-05-2016 11:00 AM
DA Limiteds vs. FA Limiteds GregX999 Pentax SLR Lens Discussion 120 08-08-2011 11:09 AM
All times are GMT -7. The time now is 02:49 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
