06-19-2018, 11:10 AM   #1
TerryL's Avatar
100mm ND, and ND Grads on the FA Limited lenses?
Hello Folks,
I getting a filter holder with ND and ND Grads for my Irix 15mm. There are lens adapters compable with all of my other lenses. Will a ND Grads work on such small lenses, or do they require a lens with a large front element?
Thank you,
Terry
06-19-2018, 12:35 PM   #2
david94903's Avatar
I use my Lee 100 filter system on all my lenses. I use step down rings as needed to make the Lee ring (in my case 82mm) fit the specific lens (such as my Pentax M20mm F/4 which has 49mm filter threads.
---------- Post added 06-19-18 at 12:49 PM ----------
For adapter rings, WPRESTO turned me on to this site. They pretty much have everything. The quality of the rings are very good, and the prices are excellent.
AdapterRings.com - Offical Site. The world's largest seller of Camera Adapter Rings.
06-19-2018, 02:42 PM   #3
TerryL's Avatar
QuoteOriginally posted by david94903 Quote
Thank you David,
I guess my question is If the ND Grads will work on the smaller lenses, or does it take a large front element? I know that the ND filters will work on all of them. Wow, thank you for the link.
Terry
06-20-2018, 07:41 PM   #4
david94903's Avatar
Hey Terry,
Yes, I think you're correct in your thinking, that the 100mm ND grad would be more effective on a lens with a larger front element. I occasionally use my ND grads on a smaller lens, it works but I'm probably not getting the full effect of the ND grad filter.
06-20-2018, 09:22 PM   #5
It depends more on FOV than on filter ring size. 100mm filters are ok on most WA/UWA lenses. Even hand held.
Gesendet von meinem Mi A1 mit Tapatalk
adapter, filter, filter system, grads, k-mount, lee, lens, lenses, pentax lens, rings, site, slr lens
25/4 and grads GarethC7 Pentax Medium Format 6 11-12-2014 10:04 AM
ND Grads milesy Photographic Technique 4 01-24-2014 10:36 PM
K5 sensor with Cokin ND Grads Billgscott Pentax K-5 & K-5 II 5 03-14-2012 09:25 AM
ND grads. ozlizard Pentax Camera and Field Accessories 4 01-11-2010 05:57 PM
Cokin filter adapter & ND grads simonkit Pentax Camera and Field Accessories 5 08-31-2007 04:35 AM
All times are GMT -7. The time now is 11:17 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
