Originally posted by GoldMountain So should I just get a reversing ring to use with the standard 18-55mm lens that came with the camera?
Reversing rings are inexpensive, though I suggest not buying the cheapest quality level. Be aware that focus with a reversing ring is done changing the distance to subject. The focus ring on the lens does nothing with most primes and very little with an internal focus zoom. As noted in comments above, lenses with aperture rings work best for reversed use.
Originally posted by GoldMountain Or do I need a K-mount bellows?
Bellows are very versatile, but a dedicated macro lens is easiest to learn with.
Originally posted by GoldMountain Do bellows come with lens mounts or do I need to buy those as well?
Except for expensive units like Novoflex that use adapters, a proper K-mount bellows should come with a proper K-mount on the front and a removable/rotatable mount on the rear. Being able to remove/rotate is very important since clearance to flash overhang may be a problem with some bodies and bellows. Note that all bellows require a lens with aperture ring. As with a reversed lens, bellows focus is best done by adjust distance to the camera rather than by extension on the rail. That is why an over/under rail configuration is handy. The top rail is used for extension (determines magnification) and the lower for adjusting distance. FWIW, a focus rail does a much better job of the latter task.
Originally posted by GoldMountain Can either of these 2 options do the trick alone or together or should I spring for a used Sigma or Tamron mentioned above?
I could do the task easily with my Pentax Bellows-K but would probably use the Tamron 90/2.8 (77B) instead. Doing with reversing ring and no focus rail would be a challenge.
Originally posted by GoldMountain And what do you recommend for lights?
When using a tent, something as simple as clamp-on work lamps with standard incandescent bulbs from Home Depot will work. Care should be taken in regards to bulb type with continuous lighting, both from perspective of color temperature and phasing (LEDs are notorious).
< $20 each at Home Depot (
https://www.homedepot.com/p/Globe-Electric-Utility-Clamp-Work-Light-6618701/300374841)
A couple of inexpensive generic manual flash with an on-camera trigger with that same tent would be more reliable from the perspective of consistent light spectrum and easy of tailoring brightness. I have two Yongnuo YN560III with YN560RX transmitter (Nikon foot) at a total outlay of under $150 USD.
Again...the tent is a key component.
There are a ton of good suggestion on this thread. I am impressed with the response.
