Originally posted by GoldMountain What do you think the focal distance will be using the Raynox 250 on top of the 18-55mm kit lens? What is the furthest distance one can focus at for good quality shots?
Note that BrianR has given some precise information.
These are the rules for Raynox:
1) with the 150 (+1.5X) with the l
ens set to infinity, the distance from the front element of the lens to the subject will be
about 8 inches regardless of the focal length of the lens.
2) with the 250 (+2.5X) with the l
about 4 inches regardless of the focal length of the lens.
3) because the front element to subject distance is the same with the lens @ infinity when a Raynox (or any close-up filter) is attached, longer focal length lenses or longer FL settings on a zoom lens will yield higher magnification.
4) how much closer you can focus by turning the focus ring on your lens depends upon the focal length of the lens and how close the lens will focus without the Raynox attached, Again, you cannot predict in advance.
5) the performance of the Raynox on a zoom lens
cannot be predicted in advance. With some zooms and some FL settings, there may be severe vignetting yet the center will have excellent IQ (see example I posted with a Raynox on a SIgma 17~70mm). With other zooms, there may be no vignetting over the entire FL range. In general, vignetting is far more likely at short FL settings with a zoom, and almost always, a good quality single focal length lens will yield better IQ with a Raynox than a zoom.
