Originally posted by AI8877 Everyone said it would be a razor sharp lens but the way I see it is not much of a difference between this and the Kit 28-105
First: Anyone saying
zoom and
razor sharp in the same sentence is over stating the sharpness other than perhaps relative to other zooms they've used.
Second: As most have already stated, you'll want to avoid the extreme range of the aperture. f/2.8 and you'll have shallow depth of field plus soft corners and edges. At f/22 you'll be suffering with diffraction. Next time try f/8, f/9.5, f/11.
Third: If you are after sharpness, generally avoid the extreme range of the focal length. So instead of 70mm or 200mm, try 105, 120, 135mm.
Fourth: Eliminate any possibility of blur. If you are shooting still objects handheld, try a minimum of double the focal length...i.e. 120mm....use 1/250" or faster. Turn off SR. I would only use SR if you had to shoot handheld with slower shutter speeds.
Fifth: The 28-105mm kit lens is an excellent lens. Most kit lenses are underrated by users. They are usually paired with the camera because they are cost effective but produce excellent results. The 70-200mm is also an excellent zoom that gives you more range and is sharper than the kit lens at 105mm.
Six: Shoot RAW and use unsharp mask or a high pass filter to enhance your image sharpness.
Last: If your holy grail is sharpness, then you must convert to Primism. I am a believer. Solid tripod and discover the power of pixel shifting. Keep Calm and Carry Prime.
