Originally posted by stevebrot Warning! Ricoh Pin may jam with the AF drive pawl.
While not all "P" series Rikenons have the "pin" variant that is sure to foul your Pentax AF camera, all potentially are sources of significant grief. Do a Web search on the term "Ricoh Pin" for many sad stories as well as guides for detection and assessment of risk.
Third Party Variants of the K-mount
Pentax made the original "K" mount available for other camera manufacturers to adopt. The goal was to create a universal standard bayonet mount much like the M42 screw mount had been. Ricoh, Chinon, and others produced cameras and lenses with the "K" mount. Unfortunately, with the introduction of the "KA" mount, Pentax reversed the decision with the result that the other manufacturers either abandoned the "K" mount or developed their own, somewhat incompatible, enhancements. Several third party lens manufacturers produce or has produced lenses with a K-mount. There are no issues with current third party lenses in K-mount, but for older lenses there are two traps to watch out for:
The infamous "Ricoh pin". Where Pentax created the "KA" mount in order to support Program and Tv exposure automation, Ricoh had to create their own variant, which has a protruding pin placed in a somewhat unfortunate location, namely in the exact spot where Pentax years later placed the autofocus drive shaft. Such a Ricoh lens will get stuck when mounted on a Pentax autofocus body - the Ricoh pin will get lodged in the drive shaft and prevent the lens from being removed without deployment of finesse, patience and tools.
The other trap is the shield that protects the aperture stop down lever. The image to the left shows what the shield should look like and does look like on a genuine Pentax lens. Some older third party lenses have a much larger shield which prevents mounting the lens on a Pentax DSLR. Current third party lenses (Sigma, Tamron, Rokinon, etc.) have correctly shaped shields (or no shields) and pose no problem.
Read more at:
The Evolution of the Pentax K-mount - Articles and Tips | PentaxForums.com
