Originally posted by pid makes not much sense, because the lens is to slow. Better get an other zoom. There are a lot better options out there.
The Pentax D FA 28-105mm is the lens I have, and will continue to use, for this walk-about purpose on the K-1-series.
My 2 years of experience with it tells me that it has very high image quality over its natural optical range.
I'm currently testing this combination: K-1ii, D FA 28-105mm, Pentax 1.4x TC.
I set the camera to
square crop mode, which eliminates the corner vignetting caused by using a converter that wasn't designed for FF, and this crop shows in the viewfinder.
So I'm just using 4912 x 4912 (24 MP) of the K-1-series sensor, and the best part of the lens field.
Initially at least, I'll use the lens wide open, hence an actual f/8.
I'll be running comparison tests on what image quality I can get, with the lens at 105mm, with or without the Pentax Converter, using Lightroom Classic CC to squeeze out the best image quality.
Pentax D FA 28-105mm lens: 440 grams
Pentax 1.4x Converter: 126 grams, and slips into a packet.
