Originally posted by Texas-expat
Has anyone found other DA lenses that are fully compatible with FF bodies?
*Fully* compatible? DA*200, DA*300, DA560. That's coming from Ricoh.
As for the rest, off the top of my head:
The DA35/2.4, DA50 and DA*55 are as near as dammit, and the DA40 and DA70 aren't far behind. The DA*60-250 works quite well if you modify the rear baffle, thus voiding your warranty.
The DA35 macro is OK (not great) at close focus only. The DA10-17 covers the full frame from 14-15mm, but (like the 35 macro) not without IQ loss at the edges. The DA12-24 is apparently also quite usable after about 14mm. The DA*50-135 is OK with the teleconverter, while the TC makes many other lenses worse. The 55-300 variants only work well around the 200mm mark.
I'm sure I've missed some, but that'll do for now
