Originally posted by danielcollada I have never looked into this before and I am finding really difficult to find any info on this.
For starters, you need to consider mount compatibility, not brand compatibility. The two are often, but not always the same thing.
For example, Voigtlander has manufactured lenses in a number of different mounts including Pentax K, Canon EOS, Nikon AIS,
Leica M and many others.
Any K-mount lens will work on any K-mount camera body, though there are some restrictions depending on the body and lens,
(for example, auto-focus lenses can only be used as manual focus on a camera body that lacks auto-focus capability).
Most any M42 mount lens can be used on a K-mount body with the appropriate adapter.
Many other mounts can also be used on K-mount with the appropriate adapter, but some pairings may yield sub-par results.
Some mounts can not be adapted without performing major surgery on the lens, and even then, may not perform to a standard
that makes it worth the bother.
The best way to go about learning whether a given lens will work on K-mount is to know the mount of the lens, then do some
research with a concise internet search. For example:
nikon f-mount to k-mount
or,
Leica R-mount to K-mount
or,
T-mount to K-mount
or something more generic, like,
adapt lens to K-mount
Here is a specific article you may find useful:
Introduction to Lens Mounts and Lens Adapters | B&H Explora
Lastly, if you know the specific lens and its mount and the body you wish to attach it to, you can post to the forums and you'll likely
get a useful 'yes' or 'no' or 'with provisions' response.
