09-15-2008, 12:54 AM   #1
frank's Avatar
A Question for DA 17-70/4 lens owners/users
Hi All,
Got chance to test out a DA1770 lens over the weekend. Seems the lens has some strange exposure behavior, especially at the tele end. The exposure is quite different from F4 to F8. At F4 it's a bit under exposed, while at F8 it's quite a bit over exposed. I used matrix metering.
70mm F4:
70mm F5.6:
70mm F8:
I wonder if all DA1770 lenses are like this, or the one I got is a lemon
09-15-2008, 02:00 AM   #2
Finn's Avatar
Huh. I've had that problem with variable-aperture zooms, but not constant-aperture ones. Do you have an aftermarket split prism focusing screen or anything? That was my problem.
09-15-2008, 02:09 AM   #3
creampuff's Avatar
frank, I didn't know you played with dolls! Just joking, bro.
A little underexposure at max aperture I can understand (light fall off) but progressive increase in exposure as you stop down is a little baffling. Perhaps a test outdoors might yield different results.
09-15-2008, 07:44 AM   #4
maybe the blades are not opening and closing correctly?
09-15-2008, 10:13 PM   #5
frank's Avatar
QuoteOriginally posted by Finn Quote
No, I'm using the original focusing screen came w/ the camera
09-15-2008, 10:15 PM   #6
frank's Avatar
QuoteOriginally posted by creampuff Quote
Yeah, thought I'd give it a try and see how it compare against the Sigma one. I hope the problem is w/ this copy only ...
09-15-2008, 10:16 PM   #7
frank's Avatar
QuoteOriginally posted by k100d Quote
That I'm not really sure. I checked the exposure at 17mm and 36mm, also slight exposure difference, but not as bad as it is at 70mm end.
09-15-2008, 10:21 PM   #8
frank's Avatar
I also checked the Sigma DC 17-70 lens, seems it also has some exposure problem at various aperture setting, but not as bad as the Pentax one.
Sigma DC 1770 @ 70mm F4.5:
Sigma DC 1770 @ 70mm F5.6:
Sigma DC 1770 @ 70mm F8:
70mm, bit, da1770, exposure, f4, f8, k-mount, lens, pentax lens, question for da, slr lens
Question to K-5 Owners kevinschoenmakers Pentax K-5 & K-5 II 3 10-19-2010 06:40 PM
Question for K-X owners. dimebagdave Pentax DSLR Discussion 6 04-29-2010 05:17 AM
A question for K7 owners dafiryde Pentax DSLR Discussion 26 09-05-2009 02:52 AM
Question for 55-300 lens owners TTQ225 Pentax SLR Lens Discussion 2 03-01-2009 02:32 PM
Question for Prime lens users ChrisN Pentax SLR Lens Discussion 15 01-28-2009 11:56 AM
All times are GMT -7. The time now is 03:01 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
