07-24-2018, 01:17 PM   #1
BruceBanner's Avatar
Proud new HD DA 35mm/2.8 Macro Owner Here (+ some silly questions)
Just wondering if there are any groups/threads here for this lens, I hope to do a lot of shooting with it
I guess I'm just working my way through all the HD DA's, I've owned the 21mm and 15mm and now this offering
I realise this also has a retractable hood (like the HD DA 15), mounting a UV filter or step up ring was slightly awkward resulting in some vignetting, does anyone know if the 35mm is in the same league of awkwardness? Or are filters a little easier to apply?
Also, has anyone managed successfully to remove the hood? I removed the retractable hood on my Tak 135 (Bayonet), because I tend to prefer a hood thaat won't be easily pushed back in when extended out, how I wish these retractable built in hoods did this on the Ltd lens line up, like a 'pull out and twist to lock' kinda movement
Cheer,
Bruce
07-24-2018, 01:27 PM   #2
Because the retractable hood retracts all the way on the DA 35, filters are less of a problem. With circular polarizer filters, however, you have to retract the hood all the way to move them.
Congrats on your new DA 35.
07-24-2018, 01:30 PM   #3
pres589's Avatar
Odd, I never noticed an issue with a UV filter on my DA 15. The one I have on there is this rather tall Hoya item. Makes using a normal pinch cap from current DA lenses easier as it's stood out farther from the lens barrel.
07-24-2018, 01:42 PM   #4
QuoteOriginally posted by northcoastgreg Quote
Thanks Greg, it was some of your images (taken with the 35) that provided the confidence to push through with the purchase!
With a cpl, you'd typically have a hood retracted anyway tho right? You're just saying that you doubly need to make sure its retracted back otherwise you're not going to be able to adjust the cpl at all, yeah? Makes sense.
QuoteOriginally posted by pres589 Quote
When I had my DA 15 I too put a UV filter on it, just for protection purposes, and indeed left the nice lens cap alone and used a pinch one, for speed sakes.
07-24-2018, 02:02 PM - 1 Like   #5
Seeker of Knowledge
aslyfox's Avatar
here are some threads you might look at
not limited to just the HD version but
Theory on DA 35mm ltd 'greatest lens ever' (?) tag - Page 43 - PentaxForums.com
HD DA 35mm 2.8 limited Macro as Lanscape lens - Page 3 - PentaxForums.com
or the SMC or DA 35mm F2.8 Macro Limited
The DA Limited Club - PentaxForums.com
and there is this thread about primes
prime, prime, everywhere a prime... - PentaxForums.com
07-24-2018, 02:12 PM   #6
QuoteOriginally posted by Aslyfox Quote
Awesome thanks!
07-24-2018, 02:12 PM - 1 Like   #7
Seeker of Knowledge
aslyfox's Avatar
if you have specific questions, I suggest that you look at the user reviews for the HD and send a pm or two
HD Pentax-DA 35mm F2.8 Limited Macro Reviews - DA Prime Lenses - Pentax Lens Reviews & Lens Database
I recently picked up an " experienced " SMC Pentax-DA 35 F2.8 macro limited
and there is the " in depth review " of the HD vs. SMC coating on the DA Limiteds you could look at as well
" HD vs. SMC Pentax Limited Primes
Introduction
At Photokina 2012, Pentax announced a brand new lens coating which they named the "HD Coating". This coating is slowly starting to replace the conventional "Super Multi Coating" (SMC) on high-end Pentax glass. According to Pentax, the new HD coating greatly reduces reflectance without making any sacrifices in terms of durability. This kind of coating isn't new to the industry, however: Pentax digital medium format lenses have been treated with a slightly less durable variant called Aero Bright coating ever since their debut, and other manufacturers have been using "nano" coatings on their premium lenses for several years.
The modern SMC coating that DA lenses have been using for about a decade now isn't the same as the SMC coating that Pentax originally launched in the 1970's. In fact, most DA lenses have been said to have a "ghostless" coating, so while we don't expect the difference between SMC and HD coating to be be a game-changer, it should certainly still be easy to observe. . . .
Read more at: HD vs. SMC Pentax Limited Primes Review - Introduction | PentaxForums.com Reviews
07-24-2018, 02:15 PM   #8
DW58's Avatar
Congratulations. I think it's a great lens. Hadn't used it for a while so took it to the coast here in Oregon just the other day. Posting photos here and there from that trip. I predict you will not be disappointed.
07-24-2018, 02:30 PM - 1 Like   #9
Congratulations to the new lens!
Just checked with my lens: you can push the hood all the way back. Step-up rings and such can be attached as easy as to a lens without inbuild hood.
07-24-2018, 02:43 PM   #10
Digitiser of Film
BigMackCam's Avatar
Funnily enough, my HD DA15 is one lens I've found to be very fussy about filters, specifically because of the hood. Actually, I think it's the black felt lining rather than the hood itself that's the issue. I don't often use any filters on it, but I have a Hoya Slim UV(c) that I leave on it, then remove for shooting as appropriate - which is most of the time, in all honesty
07-24-2018, 03:08 PM   #11
Thanks everybody, good to know!
07-24-2018, 07:35 PM   #12
Theory on DA 35mm ltd 'greatest lens ever' (?) tag - Page 43 - PentaxForums.com...
I'm just a few pages into this thread but it seems a lot of people are a little undecided on this lens being something really special. Already I am seeing a line drawn with some that are blown away by it, and others not overly. Indeed I have seen many non independent sites even talk about this lens (Sony shooters etc) that are using adapters just so they can use it!
Really excited to see mine now, c'mon mr postman! hurry up!
07-24-2018, 08:14 PM   #13
Seeker of Knowledge
aslyfox's Avatar
well,
I do know of another thread discussing the Pentax Limiteds:
the limiteds do they live up to the reputation and why - Page 14 - PentaxForums.com
07-24-2018, 11:07 PM   #14
Introduction
Yeah, I have sold the 21 and 15 HD DA's due to being what I felt produced crappy starbursts. These lenses were intended for landscape work, but I'm the kinda guy that likes a good star burst. I know now going into the purchase of a HD DA 35 Macro that it too will produce naff starbursts, but I'm ok with that, this is not really going to be a landscape workhorse (I am yet to really settle on a UWA lens, the search must go on!).
07-25-2018, 12:00 PM - 3 Likes   #15
Wingincamera's Avatar
My most used lens for landscapes is the DA 35 macro & DA 15, with the DA 50 close behind. Ithe 35 also for making pano's and focus stacking. Here is a couple from the 35
35mm/2.8 macro owner, da, da 35mm/2.8 macro, hd, hd da 35mm/2.8, hood, k-mount, lens, pentax lens, slr lens
HD 20-40 or HD 21 & HD 35 macro BarryE Pentax SLR Lens Discussion 33 09-03-2017 06:05 AM
Proud Owner of the New K-70 dustyroadphotos Welcomes and Introductions 17 09-09-2016 08:15 PM
Proud new owner of a Spotmatic F! Street42 Film SLRs and Compact Film Cameras 4 09-25-2015 01:51 PM
Was supposed to be the proud owner of 35mm Ltd by now... DaveHolmes Pentax SLR Lens Discussion 10 10-16-2011 10:30 AM
Proud new owner of K110D dc@6cc Welcomes and Introductions 5 04-06-2007 11:28 AM
All times are GMT -7. The time now is 03:32 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
