07-24-2018, 01:39 PM   #1
Gaseous Anomaly
jcdoss's Avatar
Modifying an M400/5.6
I have this lens, and I have a 1.4x-L converter that I bought for use with my K500/4.5. I've used other converters on the M400 but why do that when the L version is here? The answer is "incompatibility."
I noticed the only thing keeping the converter from sliding into the back end of the lens is a little metal spacer/baffle (see photo).
After several days of trying real hard not to strip the lens mount screws, I finally got it off (secret = apply heat, directly to screws, sometimes for a long time, maybe allowing a couple of heat/cool cycles, thanks for the advice Eric!) and removed the baffle. Once removed, the inner felt-lined barrel wants to spin, so I put the small screws back into the lens in such a way as to hold it steady, at least long enough to test if the thing will even focus.
So, here are some preliminary and fairly shabbily done results. I'll show the images in pairs in subsequent posts for comparison, but please note all I was trying to accomplish was to a) see if the lens would focus with the converter on, b) see if there were any ill effects of not having the baffle in there, and c) see what deleterious effects there are, if any, on the lens from the baffular absence.
First two images, wide open, infinity focus, 560mm on top.
PENTAX K-1 Mark II  Photo
07-24-2018, 01:42 PM   #2
Gaseous Anomaly
jcdoss's Avatar
Next two images, f/16, infinity focus. Unfortunately, I wasn't smart enough to use the construction site for all the infinity photos... maybe after subsequent modification, I'll do that.
07-24-2018, 01:43 PM   #3
Gaseous Anomaly
jcdoss's Avatar
Next, minimum focus distance, wide open.
07-24-2018, 01:46 PM   #4
Gaseous Anomaly
jcdoss's Avatar
And finally, a couple at minimum focus distance at f/16. Converters do not have an effect on minimum focus distance, just in case you did not know, and this was confirmed as I stood in the same spot for both of these photos.
Also, a photo of the round baffle thingy-madoodle that I removed to enable compatibility. Words on "issues" I encountered in the next post.
---------- Post added 24th Jul 2018 at 03:50 PM ----------
So, after removal of the round part, i discovered that the aperture mechanism sounds a little "loose" for lack of a better word. Also, if the lens is upside down (aperture numbers facing the floor, lens in horizontal position), the aperture will not close. I don't hear anything that sounds loose or free inside the lens at this time, but it seems clear the round-o was doing something more than just keeping the lens from being fully compatible with the really cool L extenders.
My curiosity is satisfied that the lens will perform well with the converter, and that the lens still performs fine without it, and without the added piece. The plan now is to modify the piece such that the straignt edges are curved enough to allow entry of the nose of the 1.4x-L. I guess that means I need to get a Dremel.
07-24-2018, 02:48 PM - 1 Like   #5
Lens Hoarder
monochrome's Avatar
Gearhead response: Nice series and experiment. Of course you could just save yourself the trouble, and the risk to damage a very nice lens, and buy an A1.4x-S TC
07-24-2018, 03:13 PM - 1 Like   #6
UncleVanya's Avatar
I suggest you 3d print one or have one machined rather than modify that ring.
07-24-2018, 04:12 PM   #7
Gaseous Anomaly
jcdoss's Avatar
Hi monochrome! I've got an S version too, and I spent several nights cleaning it up and re-tuning it because it seemed to be crapping out at infinity. I don't think it was allowing infinity focus, but I think I've fixed it. I guess the real problem is that I got a set of screwdrivers and the oppressive heat just made me want to take something apart.
Uncle Vanya, I wouldn't have the first clue how to go about 3-D printing something like this. Got a tip?
07-24-2018, 04:16 PM - 1 Like   #8
Lens Hoarder
monochrome's Avatar
QuoteOriginally posted by jcdoss Quote
Just jazzin ya Have fun!
07-24-2018, 05:27 PM   #9
swanlefitte's Avatar
Cool post. Weird about the aperture upside down.
07-24-2018, 07:32 PM   #10
Journeyman Cat Wrangler
SSGGeezer's Avatar
There are a number of places that will scan and print with a 3d printer, whatever you want. Search engines are your friend!
07-25-2018, 04:50 AM - 1 Like   #11
UncleVanya's Avatar
QuoteOriginally posted by jcdoss:
Look for a local "hacker space" and talk to the folks there.
aperture, converter, distance, effects, focus, images, infinity, k-mount, lens, pentax lens, piece, post, round, screws, slr lens
Metz M400 flash with MZ-S? rollbahn Flashes, Lighting, and Studio 5 05-25-2018 10:38 PM
Metz M400 flash $149 bladerunner6 Pentax Price Watch 4 12-20-2017 09:10 AM
Carrying solution for K-1 and M400/5.6 jcdoss Pentax Camera and Field Accessories 5 12-18-2016 06:06 AM
Nature Fun with new M400 5.6 goddo31 Post Your Photos! 4 11-07-2009 08:23 PM
I was bored. m400 + af1.7X Canada_Rockies Pentax SLR Lens Discussion 18 04-21-2009 02:41 AM
All times are GMT -7. The time now is 04:24 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
