Originally posted by tncowdaddy Right now I'm using a Pentax K-3 with a Pentax-DA* 16-50mm F2.8 and I recently acquired a Pentax-DA* 50-135mm F2.8.
I also use a Pentax-DA L 55-300mm F4-5.8. As I just spent some dough on the 50-135, I want to find out if there's a better lens out there than the DA L 55-300mm that I can move to for under $300. Ones I've looked at are the Pentax HD Pentax-DA 55-300mm f/4-5.8 ED WR Lens and several Sigma lenses (70-300mm, 100-300mm, 135-400mm). I trying to get as good a birding lens as I can get now until I can afford the $800-1200 to get a good used long lens.
I would recommend you consider spending some money and rent some lenses so you can do your own testing before buying anything
I have successfully used LensRentals.com which I believe is from Cordova TN
there are other companies but I haven't used them
then if you are interested in an " experienced " lens check out the listings by forum members in the market place " buy/sell "
_______________________
have you seen the section of the forum which has the reviews of lenses - " Lenses "
good luck
