Originally posted by Karenfreer In Manual mode you can select the shutter speed you want, I will be shooting with B&W Ilford 3200 so I will be able to select a fast shutter speed, I am not sure which aperture to use, I was thinking around f/8-f/11?
Your aperture will depend on how much light there is available if your shutter speed is going to be fixed. Indoor vs. outdoor field, good or bad lighting, sunny or hazy day… artificial lighting certainly keeps conditions stable, whereas a sunny day with some clouds passing under the sun can constantly throw your exposure around.
I guess most, if not all, Roller Derbys are held indoors, so measure the light before the match starts and you're good to go. I would also recommend getting some Fuji 1600 if you can get a hold of it before the game. Some teams are all about color in their uniforms and hair.
You won't need an A lens until you use a body which can control aperture in the "A" setting.
