Can you see trough the glass any oil or any stains on aperture blades? If not, it could be that aperture ring lubrication is dried out o stuck for some other reason. I opened 3 lenses recently
and with one that's really good, I screwed things by cleaning that grease on aperture ring, so it was very hard to rotate it
But then I took some grease from other lenses that are bad...
BTW, does anyone knows what grease could be used as substitute for that? I'm just sure that it has to be high temp resistant, so that it doesn't melt on warm days and slips on the glass or blades...
And about contact cement: what's that?
I'm using magnetized screwdrivers, ie. just rub screwdriver with magnet few times and it's holding screws quite good
