Originally posted by Just1MoreDave The official tool is a rubber ring that uses friction on just the name ring. MicroTools has it on their site. If you can find something rubber that fits just inside the filter threads and doesn't touch the front element, it will probably work.
Most name rings use the filter threads, so clean these first with a toothbrush if they're dirty. From the photo, this name ring might screw into its own threads. A few times, I have used a few drops of WD40 in the name ring threads to help a stubborn ring turn.
I had a lens like this with similar symptoms and no visible oil. Cleaning the blades had no effect. I thought the mechanism just behind the mount had too much friction. I used a few drops of WD40 there and it fixed the slow aperture. The lens worked for months that way before I was comfortable selling it as a working item.
Thanks for the WD40 tip.
I have tried a home made rubber tool, but the plate barely moved. I think it's a little too cozy in there for a rubber tool.
I'll have to resort to drilling, when I have time.
