Originally posted by stillshot2 This may be the best route. Any idea of which type of lube?
Basically, you want something that stays relatively stable across a wide temperature range, that won't run or separate. Previously, I've used marine-grade white lithium + zinc oxide grease with good results, but it can be a bit too heavy for some lenses, resulting in too much resistance. For simple, wide spaced helicoids, it's fine, but with tighter tolerances, not so much.
My favourite is Helimax XP, which is designed specifically for the lenses and telescopes. It's more expensive, but worth it. I've yet to have problems with it on any lens.
Originally posted by stillshot2 Wow I just watched a disassembly video of a similar lens and I think it is more than I want to get in to just to add some lube. Is there a way to sneak a little lube where it needs to go without taking apart so many pieces?
Honestly, no. There are no lasting short-cuts.
You can't simply "add some lube" to what's already there... These are precision instruments. You need to clean the old, congealed lubricant off the focusing helicoid first, then apply the fresh stuff.
I've known some people drip a little thinning agent into the mechanism, which might work temporarily, but you will almost certainly end up back where you started (at best) or with lubricant or thinning agent migrating into the rest of the lens (at worst - and more likely).
