Originally posted by jatrax I'll respond since you quoted me and only to clarify. Yes the old style SDM motors have a bad reputation. But the DA 16-85 is NOT SDM and has a sterling reputation with no motor failures I am aware of. It has had a few reports of a screw coming loose inside that jammed things up. That happened on mine and it was fixed under warranty. This was not a motor problem.
Yes, I know, I didn't mean to suggest that the 16-85mm had an SDM motor, but that doesn't mean it can't fail. Anything can fail.
Originally posted by Ontarian50 What amazes me about this issue, is how in-body AF motors are virtually bulletproof in comparison to their in-lens counterparts.
For decades now, we've seen cameras from Minolta, Nikon, and Pentax with AF motors in the body using "screw drive" to operate. And I'm certain I've never seen one of them die. Old bodies fail for many other reasons, but AF motors don't seem to be a weak spot.
So the puzzle is why the motor types used in lenses are so much more prone to failure?
I think it's because there's pressure on in-lens motors to be small, quiet and very fast. These are three qualities which don't go hand-in-hand with reliability.
