It could just be simple condensation.
I completely forgot that you just got the lens.
Air transport is quick, but comes at a price: huge differences in pressure and temperature.
If you don't live in a very humid place (as I do
) the lens should have recovered from condensation in the meantime.
As a general rule, if you get a new lens it's better to inspect it immediately, and f you see any suspect condensation, I'd seal the lens inside a clear plastic bag, with a bag/box of working dehumidifier.
I have silica gel bags, run through a electric oven with the door not shut, silica gel plastic boxes that change color when crystals can't absorb water anymore, and large boxes (with different crystals) that I use when I leave Thailand for a while, leaving my lenses inside a large plastic box.
If a lens has humidity in it, and there are fungal spores, the only way to avoid any chance of fungal growth is to expose the lens to UV light. A table lamp close enough should work, but I have a cheap UV lamp with E27 attachment that does its job much quicker
