08-19-2018, 08:24 PM   #16
SSGGeezer's Avatar
I repeat this frequently. I don't find this to be easy to see at a level that is obvious. I do agree that failing sdm can slow down so it gives this impression. I haven't seen any detailed studies showing a good lens with working sdm is significantly slower than screw drive on the same lens. But I have seen bad sdm that is already sluggish compared to screw drive many times.
And you can let the OP know that you will do the conversion if needed for 30.00 Uncle V.
With a KP versus an older body it may be a bit faster as a screw drive lens since the KP got a stronger and faster motor.
08-19-2018, 08:36 PM   #17
UncleVanya's Avatar
QuoteOriginally posted by SSGGeezer Quote
That was what they said about the k3. But later data suggested it wasn't a stronger motor it was a better autofocus system that was more decisive. But I don't have a KP. And I can convert the lens, or help point people to the right threads to convert the lens if desired.
08-19-2018, 08:41 PM   #18
demondata's Avatar
Notification
My copy is slow but very reliable. (Not screw drive converted). The IQ is stunning. Here is a shot from yesterday:
Generated by http://tools.rackonly.com
Not sure if relevant/accurate, but Bitdefender reported a phishing attempt when I clicked on the excellent image for a better look.
Edit: Sorry, not sure how this quote ended up in my message, my message refers to the link to the higher-rez portrait above.
08-19-2018, 08:51 PM   #19
UncleVanya's Avatar
QuoteOriginally posted by demondata Quote
This link? IMGP9382_DxO | What a face! DA* 50-135 wide open. Fill flash? | Flickr. Weird.
08-20-2018, 11:18 PM   #20
I've had my DA* 50-135mm f/2.8 for some 10 years, and have used it on a number of Pentax DSLRs, all with exceptional results. Knock on wood- the SDM keeps right on ticking so far. Mine has very accurate AF, and while not the fastest, not too slow either. It is great that the seller is near you so you can see it for yourself.
It has a wonderful design too. It is very compact for what it is, and the length and balance do not change either when zooming or when focusing. Nothing rotates or moves when in AF mode. Also, the AF/MF switch is right by where your thumb would be when holding the lens and camera while shooting, which makes "quick-shift" MF touchup a rather redundant feature. This sounds like a great deal to me! If it checks out as advertised, I think you will love this lens!
08-21-2018, 09:39 PM   #21
demondata's Avatar
Yep. Shows up as IMGP9382_DxO | What a face! DA* 50-135 wide open. Fill flash? | Flickr in the Firefox address bar, though.
08-21-2018, 09:41 PM   #22
UncleVanya's Avatar
I have to think that's a false positive since it is going where it says it should go.
09-01-2018, 07:10 AM   #23
Kathemy's Avatar
Well, update:
I decided I didn't quite have the budget for it this month, and that I might buy it later when I'm more flush.
Instead I won two auctions for the following:
Pentax KM, Pentax 35/3.5, Pentax 55/1.8, Pentax 135/3.5 (all original "K" series). hood, filters for all lenses, bag, manual, some rings. Listed as mint condition, will pick them up from the post tomorrow. Total $100.
Also a Pentax ME with Pentax-A 35/2.8. Cost $50.
I assume those are good deals.
09-01-2018, 10:35 AM   #24
c.a.m's Avatar
QuoteOriginally posted by Kathemy Quote
I think that both are great deals, especially the kit of the KM + K lenses. The K 35/3.5 is a very nice lens.
bucks, k-mount, offer, pentax lens, slr lens
8% eBay Bucks until 1159PM PT 08/04- $50 minimum required bladerunner6 Pentax Price Watch 5 08-04-2018 10:18 AM
eBay Bucks 10% in app, 8% otherwise on more than $50 until 12/6/17 1159 PM PST bladerunner6 Pentax Price Watch 4 12-05-2017 04:41 PM
What do you use to tether your K3 to laptop? Do I have to spend 50 bucks on a Tether? CeciProAm Pentax K-3 & K-3 II 8 02-05-2015 05:19 PM
LBA impulse buy! Pentax 100mm 2.8 macro $521=$599-$48(bing)-$30(xbay bucks) thomasxie Pentax SLR Lens Discussion 18 03-23-2010 06:59 PM
All times are GMT -7. The time now is 07:38 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
