Check out the "Adapted lenses tested on the Q" for a ton of information, it is a sticky in the Q section.
I've got the four lenses he talks about and I use them often on my Q7. The nice part about using them on a Q is that you are only using the center part of the lens so you get excellent edge to edge sharpness, no vignetting and no distortion. They are as good as he says, and with a rubber washer put in the back of the adapter you can get an effective f4.5 stop, which is optimum for edge to edge sharpness on the Qs. I haven't used them on bigger sensor cameras.
I would rank them as #1 50mm, #2 18mm, #3 24mm and #4 70mm. The 70mm isn't as sharp as the others and suffers from some purple fringing.
Here is a shot taken with the 18mm:
[url=https://flic.kr/p/XEYWvz]
And one with the 50mm (cropped):
[url=https://flic.kr/p/WS9NAb]
They all benefit from a hood, especially the 24mm.
Here are some MTF tests on the three smaller lenses:
http://erphotoreview.com/wordpress/?p=404&page=2
Note how the resolution increases as the lens is stopped down. Also note the distortion figure for the 50mm lens!
Reason: more info
