Show Printable Version 9 Likes Search this Thread
08-29-2018, 08:51 PM   #16
Ronald Oakes's Avatar
QuoteOriginally posted by twilhelm Quote
The thing that gets me is the 35 optics are nearly good enough to be a DF A lens.
I know. I wish it were full frame.
08-29-2018, 09:20 PM   #17
runswithsizzers's Avatar
Honestly, the whole worry with plastic mounts is, so far as my own experience goes, unfounded. The DAL 55-300 weighs nothing compared to many lenses... It will have zero impact on the plastic mount. You could fit plastic mounts to considerably heavier lenses and not have any problems. Wear and tear from constantly fitting and removing the lens is more likely to be an issue, but my DA35/2.4 shows no signs of that either...
I agree; reports of broken PENTAX plastic mounts are quite rare. However, I have been hanging out on the FujiX-Forum for the past year and I've read reports of broken FUJI plastic mounts - maybe 4, 5 or 6 cases reported in a year. Fuji uses a plastic mount on two of their kit zooms, the XC 16-50mm f/3.5-5.6 - and the XC 50-230mm F4.5-6.7 (and maybe others). As I recall, most of the broken mount reports I saw were about the longer lens.
I have both of the above zooms; the reason I bought them was to save weight when traveling by foot. I also have Fuji's mid-range XF 18-55mm F2.8-4 zoom (metal mount). The image image quality of Fuji's plastic-mount lenses is actually equal to their more expensive zooms, which is saying a lot.
I've never worried about the mount on my Pentax DA 35, but don't assume all plastic mounts are as trouble free as the ones Pentax makes.
08-29-2018, 09:39 PM   #18
QuoteOriginally posted by Ronald Oakes Quote
Isn't it, effectively?
08-29-2018, 09:45 PM   #19
twilhelm's Avatar
QuoteOriginally posted by leekil Quote
In my experience it is.
08-30-2018, 04:06 PM   #20
stillshot2's Avatar
QuoteOriginally posted by runswithsizzers Quote
Maybe broken is quite rare from normal use and not being dropped, but the plastic mount on my 55-300 DAL would shave off into the camera body whenever I swapped it. I guess the plastic was too cheap for the tight tolerances of the mount. Got rid of it quick that's for sure.
10-31-2020, 04:01 PM - 1 Like   #22
It's the other end of the lens that needs enhancement: the productive thing to do would be to add a lens hood bayonet.
11-03-2020, 03:12 PM   #23
FotoPete's Avatar
I wonder if anyone has been able to remove the aperture mask on the DAL35 such that you'd get something closer to the FA35 of which the lens is supposedly based off of.
11-03-2020, 04:40 PM   #24
Digitiser of Film
BigMackCam's Avatar
QuoteOriginally posted by FotoPete Quote
There's an aperture mask?
11-03-2020, 09:06 PM   #25
FotoPete's Avatar
DA 35mm/2.4 - A Plastic Wonder! -- DAL35 vs FA35 vs DA35m vs A35 (many photos!) - Page 8 - PentaxForums.com
The thread of the Dal35 vs FA35, a user shows a side-by-side of the rear and you can see a sort of circular mask within the DAL35.
11-04-2020, 06:06 AM   #26
stillshot2's Avatar
Has anyone tried to remove this? How necessary is it? I'd be interested in trying this if it means I got f2.
11-04-2020, 06:21 AM   #27
normhead's Avatar
Lensrentals on metal vs plastic mounts...
If the lens is damage plastic one require less repair. The metal ones tend to break the piece that holds the mount, the plastic ones just break the mount. They found no functional difference other wise.
11-04-2020, 09:45 AM   #28
stillshot2's Avatar
Curious to know if they check the plastic mounts from wear and getting loose over time because as my post above from 2 years ago stated (before this thread was resurrected), my 55-300 DAL was starting to shave off plastic bits into the mirror box. And a DA 50mm 1.8 I had also was showing quite a bit of wear too. Acquired a cheap Tokina AF lens with a metal K mount I was going to transplant to one of them but then decided to just sell off the plastic lenses and replace them with different ones.
11-04-2020, 10:33 AM   #29
normhead's Avatar
QuoteOriginally posted by stillshot2 Quote
I'd be looking or cause of use shavings. I haven't used either much, and I tend to use my plastic mounts infrequently, so it would be an investigation. But touch won\od, none of my plastic mounts have done that.
I got a DA*55 1.4 and all other 50 type lenses are history.
11-05-2020, 06:17 AM   #30
Digitiser of Film
BigMackCam's Avatar
I would think the most likely cause of wear is the lens locking pin - or possibly the AF screw - on the camera's lens mount, especially if either is a little stiff, has sharp edges and / or some amount of play. Having noticed scratches on the metal mounts on some of my tighter-fitting lenses, I now habitually depress the lens release button in when attaching a lens. I don't know if it makes a difference, but it certainly stops the locking pin from scraping against the lens mount.
Another possible cause is rough edges somewhere on the camera's lens mount, which is possible if you've been fitting and removing a third party M42 adapter using that horrible "key" they usually provide...
35mm, da, da 35mm, donor, k-mount, lens, matter, metal, metal mount conversion, mount, pentax lens, plastic, plastic wonder, post, quality, quality lens, reviews, slr lens
SMC DA 35mm f/2.4 AL All Metal mount McLaughlin Pentax SLR Lens Discussion 8 04-21-2018 01:12 AM
35mm Plastic Fantastic or Vintage 35mm Lens KC0PET Pentax SLR Lens Discussion 66 03-07-2016 07:50 PM
DA 35mm F2.4 AL "Plastic Fantastic" Review Posted! Heie Pentax SLR Lens Discussion 12 03-16-2015 05:25 PM
Has anyone used "Image on Metal" for metal prints millsware Digital Processing, Software, and Printing 2 01-10-2015 07:27 AM
For Sale - Sold: DA-21 ltd,DA-40 ltd,DA-70 ltd, DA12-24, DA 55-300 (metal mount) (Worldwide) telfish Sold Items 10 12-13-2010 06:15 AM
All times are GMT -7. The time now is 10:18 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
