08-29-2018, 07:11 PM   #1
timw4mail's Avatar
Zoom zoom zooms
There are several varieties of zoom lenses:
  • One-touch (zoom and focus with same ring)
  • Two-touch (two different rings, one focuses, one zooms)
  • Push-pull (rotate to focus, pull to zoom, may be autofocus)
And then there's the weirdest of all: the zoom lens that is most telephoto when the zoom is closest to you, and widest when the zoom is farthest away from you. (this is generally a push-pull and/or one-touch zoom).
Why do you suppose the weirdest ones exist?
And have you seen any other varieties of zoom lenses?
08-29-2018, 07:36 PM   #2
Mikesul's Avatar
The power zoom which zooms at the touch of a switch.
08-29-2018, 07:47 PM   #3
timw4mail's Avatar
It doesn't seem so weird if you consider than most point-and-shoot film cameras of the same era had push-button zooming. But it doesn't really add as much to an interchangable lens.
08-29-2018, 07:51 PM   #4
Mikesul's Avatar
Pentax made several. In fact, i believe the sdm contacts were based the the earlier power zoom contacts.
08-29-2018, 08:52 PM   #5
timw4mail's Avatar
They are one and the same.
08-29-2018, 09:49 PM   #6
UncleVanya's Avatar
Isn't one touch the same as push pull?
08-29-2018, 10:23 PM - 1 Like   #7
QuoteOriginally posted by timw4mail Quote
If the lens is shortest at the tele position, you can handle it in a more stabilized way. At widest (longest), your hand-shaking is less of an issue... deflection angle and so on...
08-29-2018, 10:27 PM   #8
timw4mail's Avatar
No, push-pull can be two-touch.
08-30-2018, 05:47 AM   #9
MossyRocks's Avatar
I always thought so
I guess there are some that aren't though
08-30-2018, 06:22 AM   #10
timw4mail's Avatar
QuoteOriginally posted by MossyRocks Quote
I always thought so
As an example:
I have a Nikon AF 70-210mm 1:4-5.6 D lens, which is an autofocus lens, so it is not a one touch zoom. The focal length is changed similar to a one touch, but it doesn't rotate (as the zoom grip doesn't affect focus).
Also I have a few examples of 3 touch zooms, with focus, zoom, and macro/close up rings.
08-30-2018, 06:28 AM - 1 Like   #11
MossyRocks's Avatar
As an example:
Thanks. Now I know more than I did when I got up.
08-30-2018, 06:56 AM   #12
timw4mail's Avatar
Learning can be fun, as can sharing knowledge
08-30-2018, 07:47 AM - 1 Like   #13
Just1MoreDave's Avatar
The DA 16-45/4 extends the most at 16mm. That ends up blocking the popup flash, but doesn't seem to affect my usage otherwise.
08-30-2018, 08:01 AM   #14
MossyRocks's Avatar
Isn't that why we are here, and to look at pretty pictures or maybe win a camera?
08-30-2018, 11:33 AM   #15
timw4mail's Avatar
QuoteOriginally posted by Just1MoreDave Quote
Huh, I didn't know that there were any autofocus zooms that are "backwards" (for lack of a better term).
focus, k-mount, lenses, one-touch, pentax lens, push-pull, slr lens, varieties
maximum available apeture of zooms at variable focal lengths of zooms aslyfox Pentax SLR Lens Discussion 2 10-23-2017 07:44 AM
Vintage AF long zooms by Sigma cyberjunkie Pentax K-1 6 02-18-2017 01:14 AM
Super Zooms vs normal zooms robert52 Pentax SLR Lens Discussion 9 10-12-2014 07:29 PM
WR zooms vs IQ zooms being considered ChooseAName Pentax SLR Lens Discussion 12 10-22-2012 03:17 PM
Cheap old zooms or cheap new zooms better? okto Pentax SLR Lens Discussion 3 11-21-2006 02:49 PM
All times are GMT -7. The time now is 03:27 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
