Show Printable Version 30 Likes Search this Thread
09-06-2018, 02:10 PM - 2 Likes   #46
THoog's Avatar
QuoteOriginally posted by EssJayEff Quote
Hm . . . You know I have never asked them to line up and race to see which one is fastest. So, . . .
On your mark, get set, go!
None of them moved a millimeter. :-(
Sorry, I just couldn’t resist! ;-)
I was thinking all of my DAs had gone between 400 and 500mph at one point or another - should we be counting air speed, or ground speed?
(My largest-aperture lens is a Cosina 55/1.2. It's somewhat "dreamy" wide open, with a rather busy "bubble" bokeh.)
09-06-2018, 04:19 PM   #47
jddwoods's Avatar
My fastest lens is actually two versions. I have am M 50mm f1.7 and FA 50mm f1.7. I have never seen the need to buy a faster lens both seem fast enough for my needs
09-06-2018, 04:55 PM   #48
Another slow-poke here - the fastest one I own is the FA 35/2
Like the other person here with an f2 lens, I'm not one for shallow DOF.
I needed a fast normal for low-light APS-C shooting, and it fit the bill. Oddly enough, it is both the fastest, and the smallest lens I own.
09-06-2018, 05:47 PM   #49
My fastest lens is DA*55 f1.4
I use it at 1.4 to 1.8 quite often because I buy it to use at night and another main reason is, it is a WR lens. Stop down to f1.6 or 1.8 will improve image quality a lot.
09-06-2018, 05:52 PM   #50
monochrome's Avatar
K50/1.2 because I collect SMC K lenses and A50/1.2 that had been heavily marked and scraped. I had it completely disassembled and rebuilt and the finish removed by Brian Gohacki to more or less hide the cosmetic marks.
In both cases I rarely use them at their widest aperture. At 3 feet DoF is only 4” so often the pistils and stamen of a large flower are in focus but the petal edges aren’t. At 15 feet DoF is 2 feet but you have to be shooting something big with a 50 to significantly fill the frame.
The benefit is the additional light when focusing on the K-1. I suppose it was a lot of money to pay just to focus by hand, but that’s what I do.
09-06-2018, 08:32 PM   #51
mikeSF's Avatar
I also have the legendary Cosina 55 f/1.2
i need to use it more.
https://flic.kr/p/aDrbVA
09-06-2018, 10:07 PM   #52
I have the A50/1.2, which I mostly use when I am interested in low light, but have been using it more recently for non-low light. The recent use has been on manual-focus film cameras, as I would normally try to use an AF lens on an AF camera.
Looking at other fat lenses, like 50mm 1.4, and the FA31, I mostly use them at the wider apertures, because I do a lot of indoor low-light photography, particularly with the 31. It looks like 2/3 of my photos with those are at wider than f/2.8. The FA43 has a lower percentage of wide-aperture usage, as that is what I use as my "normal" lens on the K-1 so it gets a lot of general purpose use, and that is not a focal length I am inclined to use for the indoor low-light photos.
09-06-2018, 11:16 PM   #53
Sandy Hancock's Avatar
The A50/1.2 is my fastest lens. I like its rendering a lot, but the chromatic aberration and lack of AF and weather sealing make it a rare choice over my DA*55 and DFA*50.
I only really keep it for sentimental reasons (and bragging rights ). The extra half stop doesn't make much difference with the high ISO capabilities of modern sensors.
09-07-2018, 02:59 AM   #54
My two current fastest lenses are:
A50/1.2
ZY Speedmaster 85/1.2
I have used both at 1.2 as I like the dreamy bokeh produced.
09-07-2018, 04:24 AM - 2 Likes   #55
OzzRod's Avatar
K50/1.2 which I picked up in a second-hand store for $105
Milky Way and a couple of planets @ f2 on K1
Strelitzia with bubbles (guessing at f2) on K5iis
Fungi macro with Raynox D150 @ f1.2 on K1
Grand daughter @ f4 (I think), with K1
09-07-2018, 04:43 AM - 1 Like   #56
While we're at it, some images with my A50/1.2
Wide open on the K-1
09-07-2018, 05:56 AM   #57
bdery's Avatar
QuoteOriginally posted by UserAccessDenied Quote
What's the FASTEST lens you own?
I was going to answer the FA 77 F1.8, then I realized I also own the FA 50 F1.4 which I never use (the FA 43 F1.9 is the one I prefer).
Also, curious to hear if you shoot at that wide open aperture often, or is it just a status thing?
Rarely fully wide open, I often stop down a bit. For instance, the 43 gets used most of the time between F2.2 and F2.8.
With the 77 I sometimes shoot wide open, though.
09-07-2018, 05:59 AM   #58
zzeitg's Avatar
QuoteOriginally posted by OzzRod Quote
Seems like that was a good investment!
09-07-2018, 02:59 PM   #59
dbs
Hi Sandy
So the patients can choose there own anesthetic........great..
Dave
09-07-2018, 03:01 PM   #60
dbs
Hi Rod
Lucky you
I only ever see f2 lenses
Dave
50mm, f1.2, hd, k-mount, lens, pentax lens, slr lens
What is fastest SD card compatible with Pentax 645Z? mtps Pentax Medium Format 14 04-21-2022 10:52 AM
Fastest M-Mode ever... if the Green Button was implemented consistently -.- Bromberger Pentax DSLR Discussion 22 09-01-2021 09:40 AM
I Assembled The Fastest 75mm Lens worth over $20,000 JK..sort of Sliver-Surfer Canon, Nikon, Sony, and Other Camera Brands 4 05-30-2018 02:42 AM
Are you really using all of the lenses you own? drabina Pentax SLR Lens Discussion 97 06-15-2010 01:01 PM
How many tripods do you own and what lenses/purpose do you use them for? gofour3 Pentax Camera and Field Accessories 17 04-09-2010 03:08 AM
All times are GMT -7. The time now is 06:59 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
