09-14-2018, 11:00 AM - 1 Like   #1
Just1MoreDave's Avatar
K300/4 Tripod mount, quick version
Recently someone mentioned the DSLRKit Tripod Mount A009 was only $20 on Amazon, and specs suggested this would work on my K300/4. So I gave it a shot and it works. The K300/4 seems to be deliberately designed so it can't take a mount, with possibly the widest aperture ring on any lens right where an attachment would go. The white lens alignment button is in the way of the remaining area. I used to think I'd make my own, then I looked at knockoffs meant for other telephotos, but never did. For this one to fit, I had to pry out the white button - it's just glued in. I think you could avoid that by modifying the ring but that's work. Anyway, the ring goes right on after removing the button. As you can see, the lens is still front-heavy. The base of the foot has a couple of hex screws and could be swapped for a longer part to fix that. The ring is lined inside with plastic so it doesn't damage the lens.
09-14-2018, 11:46 AM - 1 Like   #2
Stick a K1 on the back and it will stop being front-heavy... 🙂
-Eric
09-14-2018, 12:27 PM   #3
twilhelm's Avatar
I have a K300, and have been wondering about a tripod mount. Is it solid? I ask because it doesn't appear to have much of the lens to grab onto.
09-14-2018, 02:31 PM - 1 Like   #4
That's why the lens looks deliberately designed to not take a mount. There's a 7.5mm space for this ring to attach, fortunately with some machined grooves to grip the ring. The ring has plastic inside to assist grip and prevent damage. It seems well designed and secure enough on the lens to me. The ring is twice as wide so there is a gap. The other places to attach a mount are the aperture ring or DOF scale, which I think are thinner metal, and all different diameters so you'd need different rings. I agree that it's not ideal, I just think that's as good as this lens allows.
I forgot about mounting the camera. That does help.
09-14-2018, 09:27 PM   #5
twilhelm's Avatar
QuoteOriginally posted by Just1MoreDave Quote
I appreciate the answer. 7.5mm isnít a lot, but thatís a solid part of the lens and I believe should be enough to hold well. Iím going to have to get one to mount on mine also.
button, k-mount, k300/4, k300/4 tripod, lens, mount, pentax lens, slr lens, tripod
Is this silly? Using Pentax K300 f/4 and MA200 f/4 with Olympus m43 boby. bm75 Non-Pentax Cameras: Canon, Nikon, etc. 9 06-12-2018 01:25 PM
For Sale - Sold: K-5, K300/4, Vanguard 43, Kenko 2xTC, Quant 28-90 & Macro FF, TR-III, Grip, Filter Docrwm Sold Items 12 05-31-2013 08:59 PM
white button-ectomy and canon tripod mount on K300 f4 littledrawe Pentax SLR Lens Discussion 1 06-04-2011 10:08 PM
All times are GMT -7. The time now is 07:51 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
