09-21-2008, 06:41 PM   #1
Gooshin's Avatar
screw mount lens aperture stuck..
my takumar 135 f2.5 broke over the weekend.. i was sitting and just playing with the aperture ring going back and forth in a monotone manner, when all of a sudden it stopped going full lock, now i just go between 2.5 and somewehre between 4 and 5.6
good thing is, thats what i usualy shoot at, but now i'm debating if i should bother fixing it, or if its even fixable?
09-21-2008, 07:06 PM   #2
Did you try your own advice in your signature " if it doesn't work , hit it......"
09-21-2008, 09:15 PM   #3
troyz's Avatar
QuoteOriginally posted by Gooshin Quote
Hmmm. . . that's exactly what would happen if the auto/manual switch were halfway between "auto" and "manual". . .
EDIT: I guess I should clarify. If the switch is set halfway between "auto" and "manual", the aperture won't stop down all the way, but the aperture ring will still turn.
09-22-2008, 04:50 AM   #4
Gooshin's Avatar
the aperture ring does not move at all in auto, and only moves in that short range in manual, but does not spin through in any position
09-22-2008, 09:34 AM   #5
Just1MoreDave's Avatar
The problem is getting to the aperture adjusting mechanism, which is mostly near the mount end. Most Takumars have a one-piece mount that doesn't allow any access to this mechanism. To get to it, the lens must be disassembled from the front - not total disassembly, but close to it.
All* of the 135mm f2.5 Takumars have a nice feature that makes this considerably less tedious. They unscrew in the middle. Focus to the minimum distance, grab the protruding barrel in one hand and the mount end in the other, and turn the mount end clockwise. The front lens group comes right off, in my experience with little trouble.
You would still have to remove the focus ring (mark its position before you start to maintain infinity focus), probably the distance scales and aperture ring (watch for the bearing and don't lose it). Then you can get to some screws (probably 3)on the body of the lens that will allow the mount end to be removed. Then your problem will be revealed, hopefully.
I think it's worth fixing because it's a great lens, worth an hour of repair time, and probably something simple once you get there.
*I haven't actually owned all of them, but it worked on 2 Super-Takumars, 1 Super-Multi-Coated Takumar and even the Takumar Bayonet. The SMC Pentax (K) version also unscrews.
09-22-2008, 10:16 AM   #6
Gooshin's Avatar
thanks! i'll have something to do tonight.
also i found out that the front lens group unscrews awhile ago when i tried to take off the lens hood which i screwed on a little too tight!
10-20-2008, 07:34 PM   #7
Gooshin's Avatar
well, i finaly took the time to dig deep
and deep did i dig! i pretty much ended up disassemblign the entire lens down to the last screw.
turns out the auto-man switch was held on by two screws, that, i guess, overtime loosened and caused the aperture lever to have limited movement.
after much anger and frustration of putting it back (had to enlist the help of a tylenol bottle... for support :O)
and getting the infinity focus marker right, i put it all back together and the lens works perfectly.
the inside glass has a bit more dust now i tried my best to keep it cleen but there was ALOT of grease...
anyway, my super takumar collection is well on its way to being complete...
10-20-2008, 07:40 PM   #8
Aegon's Avatar
That is a really cool collection.
Congrats on doing the job yourself.
10-20-2008, 07:43 PM   #9
Gooshin's Avatar
QuoteOriginally posted by Aegon Quote
i was amazed to find how simple these lenses were put together (to a point)
and i didnt even have the right tools, someone slightly more clandestine than me and some really nifty tools might have had a slightly better (and cleaner) time
like an L-shaped tweaser that can pick up microscopic shit,
also those special fork-like tools to unscrew the lenses
ALTHOUGH, diagonal pressure using a small flathead screwdriver has so far worked all the time (on a number of lenses)
10-20-2008, 07:50 PM   #10
Photomaximum's Avatar
Say, how about some more info?
Can I ask you to list that collection you have? Nice photo of them all but its hard to pinpoint the exact lenses.
Also can you rate them on say a 1-5 scale? A "1" being a "sorry I bought this" and a "5" being a "only rip this from my cold dead fingers" range...
Thanks!
Max
10-20-2008, 08:19 PM   #11
Gooshin's Avatar
with the exception of the 85, all are "super takumar"
28 f3.5
35 f3.5
35 f2.0
50 f1.4
55 f1.8
135 f3.5
135 f2.5
and the "super-multi-coated" 85 f1.8
the 135 f2.5 and the 85 are by far the most stellar, images are so crisp i get cuts on my eyes just by looking at them.
the 50 and the 55 have gottent he least use (no idea why) but when i did use them i didnt have any beef with any of them.
again you dont shoot brick walls at wide open, so what some may report as "soft" is very subjective.
i havent used these lenses too much so i wont venture into specifics, but overall i am quite happy with this collection so far.
the biggest pain the butt is probably changing them, and focusing, since i dont have a katz eye yet.
10-20-2008, 08:42 PM   #12
Thanks!
Great collection of classic Pentax glass.
Well done!
Max
10-20-2008, 09:45 PM   #13
Another question if I may...
If you were held at gun point and had to decide between the 135 and the 85 which would you choose?
Would you be basing this decision on the crop factor of the DSLR you use? Another way of asking this would be if you were using a film camera or a FF digital which lens would you choose?
Thanks,
Max
10-20-2008, 11:07 PM   #14
Gooshin's Avatar
i find more use for the 85mm field of view in my current shooting style more so than 135
so if this was FF i guess i would be reaching for a bit more often.
01-21-2009, 10:45 PM   #15
Tdo0003's Avatar
Nice photo of the collection.
aperture, k-mount, lens aperture, pentax lens, screw mount lens, slr lens
Screw Mount lens on K100DSuper cyfly Pentax DSLR Discussion 5 08-30-2010 07:29 AM
K-Mount to Screw Mount Adapter Ring is Stuck steve101a Pentax SLR Lens Discussion 27 03-24-2010 02:59 AM
For Sale - Sold: Soviet Tair-11A 135mm/2.8 Screw Mount M42 ( 20 Aperture Blades! ) arpaagent Sold Items 6 03-26-2009 05:23 AM
? about M42 screw Lens to K mount adapter whitedogone Pentax SLR Lens Discussion 15 07-18-2008 01:39 PM
Screw mount SMC Pentax lens FLASH Pentax Film SLR Discussion 23 03-04-2007 09:24 PM
All times are GMT -7. The time now is 03:07 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
