09-27-2018, 06:15 AM   #1
Kim Coxon's Avatar
Irix vLaowa comparison
Has anyone seen or know of a test published comparing the Irix 11mm and the Laowa 12mm?
09-28-2018, 04:19 AM   #2
Scroll down on this link from dpreview.com.
And this one.
09-28-2018, 05:01 AM   #3
bdery's Avatar
QuoteOriginally posted by Kim Coxon Quote
The Irix 11mm test has been published here a short while ago.
The Laowa 12mm test should be published in the near future, it will go to editing soon.
I can tell you my conclusion already. The Irix 11mm is a very good lens, with some compromises optically.
The Laowa 12mm is a superb lens, with few optical compromises and amazing build quality. It's more expensive but if Pentax made a 12mm Limited, this lens would be it, or close to it.
To me there is no contest: the Laowa is superior regarding sharpness, distortion, handling, CA. It focuses closer also. Vignetting is bad (and easily corrected) on both, bokeh a bit better on the Irix (not very relevant on a ultra wide lens). The 12mm is more compact, but close to the same weight (it's dense and hefty).
If money was no object, I'd go with the Laowa without hesitating. That being said, the Irix is much cheaper and pretty good in its own right.
09-28-2018, 05:12 AM   #4
Kim Coxon's Avatar
Many thanks for the link to the test. I have seen many comments on both but these days it is much more difficult to judge reviews. Different people have different expectations of lenses and this does tend to be reflected in their reviews.
There do seem to be advantages to both. The Irix in the blackstone version is weather resistant, cheaper and has a slightly wider angle of view. I know 1mm is not critical in judging more normal lenses but in this range the relative difference is much greater. On the other hand, the Laowa has the aperture ring which makes it usable on film bodies, is faster and more compact. So at the moment bearing in mind all the various comments it was about 50/50 which is why I was interested in a direct side by side comparison.
09-28-2018, 05:19 AM   #5
bdery's Avatar
When the review of the Laowa comes out you'll be able to do mostly that. Lenses are tested always in the exact same way, and reviews are built so they can be compared to one another.
For the time being, you have to take my word for it.
I agree 1mm makes a difference at these angles. However remember that if you plan on correcting distortion via post-processing, you will loose all of that 1mm advantage and more. The Laowa's distortion control truly is impressive, as is corner sharpness.
09-28-2018, 05:19 AM   #6
bdery's Avatar
11-24-2018, 07:20 AM - 3 Likes   #7
Kim Coxon's Avatar
Decision made.
XF1  Photo
11-24-2018, 10:13 AM   #8
Journeyman Cat Wrangler
SSGGeezer's Avatar
Decision made.
Post some images soon Kim!
11-25-2018, 06:57 AM   #9
bdery's Avatar
For those interested, the laowa 12mm review has been published!
11-25-2018, 08:52 AM   #10
Kim Coxon's Avatar
It was one of the things which helped the decision. Having said that, Irix did a sale price on their 11mm lens in the UK with the Blackstone version selling at the same price as the Firestone and both reduced to about half the normal price of the Blackstone. Same with the 15mm but I do have the 15/3.5 A lens to cover that.
irix, k-mount, pentax lens, slr lens
Ultra wide angle Irix 15mm or Irix 11mm matroxication Pentax K-1 67 09-19-2018 10:01 PM
Irix 15 filter holder? TerryL Pentax SLR Lens Discussion 11 06-25-2018 11:36 AM
Pentax IRIX Blackstone 15mm for the price of the FireFly on IRIX USA Site (475$) Weevil Pentax Price Watch 7 11-25-2017 03:51 PM
The 11mm Irix f4 Blackstone longbow Pentax SLR Lens Discussion 8 11-05-2017 06:44 PM
Irix 15mm f/2.4 Lightroom Lens Correction Profile! kvetcha Pentax SLR Lens Discussion 6 03-18-2017 03:10 PM
All times are GMT -7. The time now is 05:51 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
