09-22-2008, 04:05 PM   #1
Should I pull the trigger on the DA*200MM?
Current lenes.
K100D Kit DA 18-55MM & DA 50-200MM (wifes camera bag) that I use for happy snaps sometimes
K10D Kit DA 10-17MM fisheye DA 14MM DA 16-45MM DA 40MM LTD DA 70MM LTD DA*50-135MM
Now should I sell the DA 16-45? get the lucky dip DA*16-50MM or just get the DA*200MM and keep the DA 16-45? and later on put in the DA 21MM LTD in the lineup?
I luv the DA*50-135MM but need more MM when shoting birds @ dusk low light.
LBA is HELL
09-22-2008, 07:18 PM   #2
8540tomg's Avatar
No problem at all Pentaxkangaroo. Buy the 200mm and keep all the rest. You will love the extra reach of that lens. LBA problem solved and you won't regret the one that got away.
Cheers
Tom G
09-22-2008, 07:53 PM   #3
If the 135mm isn't long enough, perhaps 200mm won't cut it either. I'd suggest sacrifice 1 stop and get a 300mm f4. Upgrade to the K20d and you'll have better high iso performance, meaning the f4 will be more than adequate.
da, da*50-135mm, k-mount, kit, ltd, pentax lens, slr lens
Help me! Should i pull the trigger?!?! Silverkarn Troubleshooting and Beginner Help 27 08-19-2010 10:06 PM
About to Pull the Trigger on Sigma 120-400 but... [Double Post] flash1100 Pentax SLR Lens Discussion 5 09-09-2009 12:44 PM
Pull Trigger: K20D... jocko_nc Pentax DSLR Discussion 7 12-10-2008 06:42 PM
Lockport NY: *istDL user getting ready to pull the trigger on a K20D MJē Welcomes and Introductions 4 08-26-2008 07:14 AM
I am about to pull the trigger...(last minute suggestions wanted) fannibal Pentax SLR Lens Discussion 28 06-10-2008 03:18 AM
All times are GMT -7. The time now is 05:15 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
