A is the SMC, it has a visible halo on the lower right corner.
My Auto Takumar 1.8/85mm has more halo, and I like it a lot for portraits.
Guessing about the other two is difficult. It depends on which Zeiss. The ZK? The old Contax one leitaxed?
In the first case I'd say that B is the A* and C the Zeiss.
In the second case it could be the opposite. Because I don't know which Zeiss it is, I stick with my first answer.
Both have not so nice bokeh.
Never tried the Zeiss, but I own the A* since long. Best 85mm of its time, not the best bokeh though.
I had the M 2/85mm long long time ago, across the seventies and the eighties. Not a bad lens but I would get it mostly for collection. The size is its atout. Because of the great size/performance ratio the 4/20mm and the 2/85mm are the only M lenses that really stand out (together with the M* 300mm), and the only ones that I have sold and would be happy to buy back.
The SMC is another interesting lens I would buy, cause it should render quite differently from the Auto Tak, and is also multicoated (better contrast).
If I remember correctly, the design and the speed changed from the Auto to the Super (f/1.9 and one more element), and the Super Multi Coated just introduced the new coating. The SMC Takumar went back to f/1.8 and was substantially the same lens as the one tested.
Now I can read the other posts... I didn't want to be conditioned
